cruise control
Old Apr 2, 2013 | 09:26 PM
fougazi's Avatar
fougazi
cruise control
I noticed while drivingmy 2012 F-250 with the cruise control on, the turbo goes up and down almost surging as if it can't find a happy medium. It happends at all different speeds. The highway was flat and no wind and no load. Is this normal? Also the truck was not in regen.
Old Apr 2, 2013 | 09:53 PM
jdadamsjr's Avatar
jdadamsjr
I've never paid that much attention to it and I cruise ALL the time...
even when towing heavy....
yes, it does spool up and down, but not excessively IMHO...
Old Apr 2, 2013 | 10:04 PM
fougazi's Avatar
fougazi
I could feel it in the truck.
Old Apr 3, 2013 | 12:05 AM
His/Hers 6.0s's Avatar
His/Hers 6.0s
Turbo boost is the one indicator that you have that shows what the engine is doing when at a constant speed on cruise. It's constantly making small adjustments to maintain speed close to your desired speed. I noticed mine does it, but not to the extent that you can really feel or hear it.
Old Apr 3, 2013 | 12:35 AM
kper05's Avatar
kper05
Without the truck in an active regen, that doesn't seem normal (since you feel it).
However, my truck has this exact behavior in regen with cruse on.
Always has. You can see the boost gauge surging and sometimes feel it.
Old Apr 3, 2013 | 04:52 AM
2ndStroke's Avatar
2ndStroke
My boost will jump around slightly while in cruise, but I can't say its been to the point that Ive felt it.
Old Apr 3, 2013 | 06:58 AM
djousma's Avatar
djousma
Originally Posted by kper05
(snip)
I've noticed this behavior too.
Old Apr 3, 2013 | 08:03 AM
U235Fishin''s Avatar
U235Fishin'
Cruise and Turbo Surge
Yep. I have seen it also, but infrequently. Cruise, straight, flat, no wind, not in regen at about 65 mph, I have seen a repeating oscillation about every 5-10 seconds from about 5 psi to about 11-12 psi. This lasts for maybe 5-7 minutes. I can feel a slight power surge. This happens infrequently and usually the power surge is what draws my attention to the boost pressure.
Old Apr 3, 2013 | 08:32 AM
Hdslider's Avatar
Hdslider
Ditto. Same here. I just cancel it for awhile then good to go.
Old Apr 3, 2013 | 08:52 AM
jdadamsjr's Avatar
jdadamsjr
Youse guys must have MUCH better eyes than I to see that little difference in THAT little, tiny, miniscule boost gauge
come on - give it up - you got a real gauge instead ?!?
Old Apr 3, 2013 | 10:15 AM
djousma's Avatar
djousma
It actually gets my attention more on the Instant Fuel Mileage display because you see that going up/down pretty regular., along with the seat of the pants feel.
The odd thing is, is that if you just cancel cruise, and reset it, then it seems to stop doing it. I always just assumed a "programming problem", but never felt strongly enough to try to get Ford to fix.
Old Apr 3, 2013 | 11:49 AM
parkland's Avatar
parkland
Is there any way this is a passive regen?
I don't have a 6.7, but I know they can do passive regens.
Old Apr 3, 2013 | 01:43 PM
Painted Horse's Avatar
Painted Horse
The Passive Regen is just excess heat burning off the soot in the DPF. It takes place when you have EGTs above 572°. Most freeway driving on flat roads will produce EGTS around 470-490°. So unless you are towing or climbing a pretty steep grade, your are not getting Passive Regens during normal freeway driving.
Old Apr 3, 2013 | 07:12 PM
kper05's Avatar
kper05
There is a PCM firmware update under TSB 12-5-12.
This addresses false DTC's about the turbo (along with many things included in previous TSB's), which I found out can simply disable the turbo while you are driving down the highway and not spin up again.
It also addresses low speed turbo surge.
This, in my mind, was a coding issue.
Otherwise the PCM should have never "thought" there was an issue.
Even if it did think there was an issue, I didn't get a CEL which it should have thrown as soon as the truck lost boost.
Maybe someone will experiment and discuss with their dealer if this could be a fix for the non-AR highway speed surge.
Old Apr 3, 2013 | 07:36 PM
sbryan's Avatar
sbryan
Just a thought since I don't have my diesel truck yet but with my gas job, when I run the cruise control the computer constantly hunts to try to maintain the set speed. I've observed this on several different vehicles, Ford and otherwise. Its my opinion that computers, as digital devices, aren't real good at mimicing real world inputs on speed. Where you or I might allow the speed to drift down a little on a small rise, the computer will apply more accelerator to try to maintain the set speed. I find that, while I use cruise a lot on the highway just so I don't worry about losing track of my speed and earn a performance award from the local cops, I also don't get as good gas mileage as I can if I focus on managing my speed manually. And I think that is because the cruise is constantly adding a little more throttle to try to maintain the set speed.
But I could be all wet too.
