Power steering fluid
Old May 29, 2006 | 02:49 PM
Dan F 2's Avatar
Dan F 2
Question Power steering fluid
Please tell me if I have done anything wrong.
My owners manual says to use Motorcraft Mercon in my power steering.
I couldn't find any Motorcraft power steering fluid.
I siphoned all of what was in the reservoir out. (It was Red), and refilled with Prestone power steering fluid for all Ford and GM vehicles. (It was clear)
So now I have a mixture. Is that OK?
Also, Is synthetic brake fluid (Prestone) ok to mix with fluid that doesn't say synthetic?
Thanks,
Dan
Old May 29, 2006 | 04:00 PM
andy6432668's Avatar
andy6432668
most power steering systems use auto. transmission fluid since it is ford use mercon. as for brake fluid if it 3 or 4 dot fluid should be fine as long it is not the silicon brake fluid which will not mix with reguler brake fluid.
Old May 29, 2006 | 04:53 PM
donaldm's Avatar
donaldm
I did the same thing!
Did the same thing using regular Power steering fluid . . . . it didn't work. I got wheel woble or jurking of the wheel when I turned. I quickly re sucked out as much as I could and refilled it with trans fluid . . . repeted the process about 5 time before I got the woble out. Bottom line is dont do it!
Old May 29, 2006 | 05:51 PM
RangerPilot's Avatar
RangerPilot
Completely purge the resevoir and system, there are instructions in the tech thread I believe. Refill with auto tranny fluid or PS fluid.
RP
Zach
Old May 29, 2006 | 07:22 PM
Noble Lumpkin's Avatar
Noble Lumpkin
Mercon is ATF. Any auto parts store ha it. If I were you I would have the PS purged and refilled with Mercon ATF. Why would you want to mix the Break Fluid???
Old May 30, 2006 | 02:05 PM
Dan F 2's Avatar
Dan F 2
The prestone tech. hotline guy assured me that their power steering fluid is compatable with Mercon!
rloomis482
Feb 13, 2013 05:43 PM
Domestic_Nuwbee
21
Nov 19, 2010 10:09 AM
6CylBill
71
Aug 8, 2010 06:44 PM
Flying_Dutchman
British Columbia
13
Jan 28, 2009 02:43 PM
Blue Steel
Sep 30, 2006 11:30 PM
