Affordable code reader?
Old Sep 21, 2012 | 12:27 PM
  #31
empiretc's Avatar
empiretc
Thanks Tim.
Stewart, would ANY predator work as a simple code reader, or do we need to find one that is F**d specific?
Old Sep 21, 2012 | 12:38 PM
  #32
timmyboy76's Avatar
timmyboy76
stuupppiidd....i unpluged the MAP, ICP, w/g sensor..etc, couldnt get to ebp sensor since i have it ziptied off/outta way...and nothing .
Not sure whats goin on, bud, but i put it on everything ,that damn scanner read the ebp on buddys truck after we cleaned the tube/sensor.
Old Sep 21, 2012 | 12:41 PM
  #33
Stewart_H's Avatar
Stewart_H
I responded to your PM, but I'll also post here.
I know my Predator (set up for my Gen 2 L) will read any OBD 2 compliant vehicle, so based on that, any DiabloSport Predator should (assuming here) work as a code reader, whether or not it's for a Ford or not.
Stewart
Old Sep 21, 2012 | 01:48 PM
  #34
empiretc's Avatar
empiretc
So you couldn't get it to read anything either?
Old Sep 21, 2012 | 02:15 PM
  #35
dsquared's Avatar
dsquared
David: Don't know where you are at, but I would be gland to lend you my Predator if needed. PM me if you want.........good luck!
Old Sep 21, 2012 | 02:34 PM
  #36
empiretc's Avatar
empiretc
Thanks Don, but it's a hell of a stretch from Canada to the mexican border, LOL.
Old Sep 21, 2012 | 02:43 PM
  #37
dsquared's Avatar
dsquared
David:
No problem bud. One nice thing about the Predator: you can download a program from DiabloSport web site called Data Viewer. You CAN monitor and record live data
Old Sep 22, 2012 | 11:55 AM
  #38
empiretc's Avatar
empiretc
Bump...
You really didn't get any results Tim?
Old Oct 14, 2012 | 11:38 PM
  #39
empiretc's Avatar
empiretc
CONFIRMED!!!
the ELM327 + torque app is money well spent!! everyone looking for an affordable diag tool, this is what you need to get!!! it's really nice when using a tablet.
Old Oct 16, 2012 | 12:02 AM
  #40
BigAlsPSD's Avatar
BigAlsPSD
I have heard both ways on the torque app.
What kind of features?
Curious if it will pull IDM codes for specific injectors.
Can you view any live data or perform tests?
Old Nov 8, 2012 | 08:48 PM
  #41
1fixitman's Avatar
1fixitman
Bump and subscribed.
Old Nov 8, 2012 | 08:52 PM
  #42
empiretc's Avatar
empiretc
Posted a type of update here:
https://www.ford-trucks.com/forums/1...l#post12463845
You can monitor injectors for misfires, but there is nothing like the buzz test. if you have an earlier model 7.3, it is best to get something better since it will not work very well at all.
Old Nov 9, 2012 | 02:24 AM
  #43
SkySkiJason's Avatar
SkySkiJason
I'm very fond of the Scangauge II. It will monitor almost everything AE does and displays (4) parameters at once - as well as read and clear codes. I have Aeroforce Scangauges in both PSD's now, but still keep SGII in the glovebox. I've used it dozens of times to pull/clear codes in other OBDII vehicles over the years - and it can be found under $120 on sale...
I gotta read that thread about the Torque app. I never could get it to work for me.
Yes, I have SGII, AF Scangauge, Torque, AE and (4) gauges on A-pillar. Kinda geeky for a redneck, huh?
Old Nov 9, 2012 | 08:46 AM
  #44
empiretc's Avatar
empiretc
The Torque app does not like your 2000/2001 the same way it does not like my 1999. It really does not seem like they are ever going to update that since there have been very few requests on their support forum, and the ones that are there went unanswered. Don't get me wrong, it is very cool and works well. Did some diags on my mom's 95 Lincoln and was able to find the problem no one else could. Also helped a friend find out he has a bad injector on his 97 Expy. Not a bad diag tool for ~$15.
The scangauge looks really cool, but is over $100. We were on a quest to find something fast/easy/cheap for pulling DTC codes specifically on our 7.3l trucks. In the end, we found a VIN locked SuperChips 1705 is really the best/cheapest option.
jaminjer
24
Nov 26, 2008 09:44 AM
kstones63
Apr 21, 2008 11:43 PM
ilbigmike
Garage & Workshop
Dec 29, 2005 11:26 AM
gdw3138
Mar 8, 2005 12:16 PM
RyanB
May 27, 2003 11:56 AM
