Column Illuminator
Old Sep 13, 2012 | 08:59 PM
nutinbutford's Avatar
nutinbutford
Column Illuminator
Hey all
Finally get back to my restoration...7 years and counting.
I'm having trouble with the light on the column (PRNDL indicator) on my '77 F100, non tilt, no cruise. Using a multi meter I have 12 volts to the copper landing pad where the bulb socket fastens in. I've tested the bulb and socket in other parts of the dash to rule that out.
I've cleaned the copper pad with a pencil eraser, it's clean. I've tried other bulb/socket combos....same result.
I'm wondering if it's a ground issue however all other illumination lamps function.
Any thoughts?
Thanks
Old Sep 13, 2012 | 09:24 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by nutinbutford
Hey all
Tilt wheel not offered until 1978 and 1978 was also the first year to offer a illuminated shift indicator dial. Note the applications for the dial.
D3TZ-7A110-A .. Shift Indicator Dial PRND21 / Reproduced
1973/77 F100/350 C4/C6 / 1973/77 Bronco C4 / 1975/77 Econoline C4/C6/FMX
Dials used in 1978/79 are different, tilt wheel different from non tilt wheel.
Old Sep 13, 2012 | 10:00 PM
nutinbutford
Thanks Bill for your follow up. It's not the dial indicator I'm having trouble with, it's getting the bulb to illuminate.
I have the Ford Wiring Diagram for the truck. The splice code 806 has the other dash lights joining there. The ground is to the Y Brace behind the dash cluster. It appears good.
Could a defective switch cause this issue?
Rick
Old Sep 14, 2012 | 03:26 AM
NumberDummy
Yes, I realize that, but there's no illuminated shift lever dial illustrated or listed in the truck parts catalog until 1978.
You have a 1977, so what parts are you using?
Old Sep 14, 2012 | 08:40 AM
VocaTexas's Avatar
VocaTexas
What is the build date on your plate? You may have an early '78 model built in late '77 calendar year.
Old Sep 14, 2012 | 11:33 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Hey Bill, I think the part the OP is reffering to is basic# 13711 socket and 13466 bulb. You can see this in the diagram section 35 page 15. It's part of the turn signal switch.
To the OP, it does sound like a ground issue. Seeing that you have 12V to the bulb, you've tried different sockets and checked the bulb, I would trace the ground circuit for that particular bulb. As to whether it could be the switch, I've never seen one fail like this but seeing as the bulb is part of the switch I guess it's possible. If all else fails in the troubleshooting I would say replace the switch.
Old Sep 14, 2012 | 08:41 PM
nutinbutford
Thanks guys.
The truck was assembled in MI in September of '76.
Here's a pic of the bulb/socket and the socket in the column. I'm using a 194 bulb.
Old Sep 15, 2012 | 10:14 PM
nutinbutford
thanks mikeo0o0o0, might have found the issue...I'm using a 194 bulb, in your post you mentioned a 13466 bulb, and yes I see that in the diagram now. Don't know why I didn't see that sooner....I'll report back.
Old Sep 15, 2012 | 10:58 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The 13466 is Ford's basic part number for the bulb.
Bulb, transmission selector dial
D8TZ-13466-A
Industry # 1445 H/D
Old Sep 19, 2012 | 08:31 PM
nutinbutford
found the problem!
looking at the pic in my earlier post...there's a small copper ring to the right of the copper landing spot where the bulb and base fasten in. I was missing the small screw that goes in there. Once I inserted the screw...tada! the light came on.
thanks guys for your input.
Rick
joecope988
Dec 19, 2018 09:55 PM
78 f150 400
Jul 2, 2017 10:41 AM
whackit
Mar 24, 2013 05:06 AM
GaryLP
Apr 19, 2012 07:33 AM
RJP66F100
18
Aug 7, 2010 10:36 PM
