1978 F150 Gearshift light
Old Jul 1, 2017 | 09:12 PM
78 f150 400's Avatar
78 f150 400
Can anyone tell me how to replace the bulb in the column mounted gearshift indicator for my 78 model. I have only found 1 thread on this and it seemed like there was conflicting info vs older columns as to whether or not the steering wheel and upper column parts had to be removed.
Is it simply by removing the lower trim cover from the dash and looking up the column from the back? It is definately a 78 model.
Old Jul 2, 2017 | 07:53 AM
corvair62's Avatar
corvair62
I could be wrong...but I'm fairly certain you will need to remove the steering wheel. If I recall correctly the light is part of the turn signal switch. So once the wheel is removed you should have no problems changing the bulb.
Old Jul 2, 2017 | 10:34 AM
beartracks's Avatar
beartracks
Don't quote me but it seems like you can pull the bezel (indicator off) and get to it there. It clips into place.
Old Jul 2, 2017 | 10:41 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The shroud is a separate part, it's not part of the dial. Both are located on the upper flange. There's no way to access the bulb, because it's inside the flange.
The plastic shift dial pointer slips into a slot of the shift collar. The bulb socket is part of the T/S switch.
From what I see in the parts catalog pic, the only way the bulb can be accessed is by removing the steering wheel and the T/S switch, as the bulb is located on the front side of it.
Transmission selector dial lamp bulb is industry #1445 H/D
GamalienaireIV
Apr 27, 2015 09:30 AM
79FordBlake
Dec 30, 2009 03:25 PM
Justntimeracing
38
Sep 28, 2004 07:46 AM
ford390gashog
Feb 24, 2004 07:37 AM
orangeford
Apr 17, 2002 02:22 PM
