Thanks for advice
Old Sep 12, 2012 | 09:21 PM
tbax46's Avatar
tbax46
Thanks for advice
Just dumped a sizeable chunk of change on preventive stuff for my 6.0. Did most of it from advice found here. Did the EGR delete and the tuner (set to the first setting above stock), also new oil cooler, blue spring regulator, ARP studs, new o-rings in injectors and had the recall done on the fuel injector harness and the exhaust pressure sensor.
Hope this takes care of things before they happen. The cost was probably about the same, if they had gone out, but at least I got the pick the time and place for repairs instead of on the road somewhere.
Will find out when I hook up the 5th wheel and take off this week.
However, thanks to all who made suggestions as to what to look out for.
Old Sep 12, 2012 | 09:44 PM
daddykitty's Avatar
daddykitty
what about coolant flush, coolant filter, check t-stat before you tow, have batteries load tested individually, alt checked, voltages, etc, fuel filters
Old Sep 12, 2012 | 09:48 PM
tbax46's Avatar
tbax46
They did a complete flush (that's what I took it for in the first place) and even replaced the degas bottle (too much sand in the old one) and checked the water pump.
Old Sep 12, 2012 | 09:54 PM
tbax46's Avatar
tbax46
Also did oil change and the fuel filters were done 4,000 ago.
Old Sep 12, 2012 | 09:55 PM
daddykitty's Avatar
daddykitty
oem filters?
Old Sep 12, 2012 | 10:19 PM
tbax46's Avatar
tbax46
Originally Posted by daddykitty
oem filters?
Yes, this was done at the Ford dealership
Old Sep 12, 2012 | 10:30 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Good job on doing it right
Old Sep 12, 2012 | 11:50 PM
daddykitty's Avatar
daddykitty
did you get a scanguage to monitor temps, voltages and such?
Old Sep 13, 2012 | 08:23 AM
69cj's Avatar
69cj
Excellant reason to install that coolant filter. Trust me they didn't get it all.
rotun
Nov 22, 2016 08:40 PM
FL SuperDuty
May 25, 2015 02:34 PM
waylove
Apr 17, 2015 08:11 PM
wycowboy
Apr 6, 2013 09:16 AM
timmyboy76
Feb 20, 2011 11:16 AM
