upgrade info
Old Apr 16, 2015 | 08:08 PM
waylove's Avatar
waylove
upgrade info
I am new to the 6.0 fam and was hopping to get some info on what are th best up grades for a 2006 6.0
Old Apr 16, 2015 | 08:16 PM
78fordman's Avatar
78fordman
performance or reliability? For reliability, start with a blue spring update (oem), oem fuel filters, oem oil filter and cap, 5w-40 synthetic oil, cat ec-1 coolant and a coolant filter, egr delete and a min 140 amp alternator.
performance - studs, tuner is most common.
Old Apr 17, 2015 | 03:15 AM
waylove's Avatar
waylove
best upgrades
Performance and reliability would be great. I am taking it to Left Coast Diesel tomorrow to get it check out.
Old Apr 17, 2015 | 09:37 AM
Rusty Axlerod's Avatar
Rusty Axlerod
First thing on my list, an OBDII monitor to see what condition it's in. Temp difference between oil and coolant, fuel injection control module (FICM) voltage, battery and charging system condition, and high pressure oil system health can all be checked from the drivers seat and monitored occasionally while you own her.
https://www.ford-trucks.com/forums/1...eral-info.html
https://www.ford-trucks.com/forums/s...09&postcount=6
Factory updates for known issues include:
-A new stiffer spring for the fuel pressure regulator will raise fuel pressure at the injectors.
-A new design on the turbo oil drain improves oil flow out of the turbo.
-A new design on the turbo oil feed line eliminates it possibly shedding the flexible lining.
-A new design on the stand pipes (under the valve cover) includes a Teflon support ring behind the rubber o-ring to reduce the tendency of the o-ring to wiggle around as the pressure fluctuates, causing it to wear.
-A new design on the dummy plugs for the same reason as the standpipes.
-A new design branch tube connector to replace the snap to connect (STC) fitting between the high pressure oil pump and the plumbing to the injectors. The snap part of the STC fitting is a common failer.
You truck has the later designed EGR cooler that often fail, especially if the oil cooler clogs up and limits coolant flow to it. Aftermarket units are available that have CARB approval, or better yet an EGR cooler delete kit would be a great mod.
I think a thorough flush, fresh silicate free coolant and a coolant filter is also a good idea.
I've probably forgotten something but that should be plenty to keep you (and your wallet) busy for a while
Congrats on the truck!
Old Apr 17, 2015 | 10:53 AM
waylove's Avatar
waylove
best upgrades
Thx i wll take all th info i can get. Just need the truck to last ya know my son and i race BMX and so we are on th road a lot.
Old Apr 17, 2015 | 11:08 AM
Rusty Axlerod
After the stuff I mentioned above comes replacing the plastic CAC tube and boots, alternator/charging system upgrades, head studs, then a tuner or FICM upgrade and tuned, larger injectors and turbo, maybe a lift, wheels/tires, lights, bumpers... The posibilities are endless
Old Apr 17, 2015 | 11:53 AM
69cj's Avatar
69cj
I noticed you live in Ca. If you have emissions testing you need to rethink the egr delete and tuner.
Old Apr 17, 2015 | 07:49 PM
waylove's Avatar
waylove
up grades
I do live in cali so I will not do to much work to the emissions.
Old Apr 17, 2015 | 08:11 PM
WatsonR's Avatar
WatsonR
If you chemically flush the coolant, be ready to do the oil cooler as it will probably plug it from all the junk in the system.
FL SuperDuty
May 25, 2015 02:34 PM
bismic
Jan 2, 2014 09:34 AM
mustang9701
Aug 7, 2013 09:40 AM
Dino's F250
Jun 8, 2013 08:13 AM
matty169
Jan 3, 2011 07:56 PM
