interior lights
Old Sep 11, 2012 | 01:39 PM
popeye47's Avatar
popeye47
interior lights
Hi,
I just changed the light switch as i had no main or high beams, This solved the problem. Now though the interior light delay does not work. I.e. before the interior lights would stay on until you put the key in. Now they go off when the door is closed?. Its not a big deal but it would be nice to fix it, Any ideas!!!!!
Old Sep 11, 2012 | 04:11 PM
alloro's Avatar
alloro
Does turning the dimmer effect the interior lights in any way?
Old Sep 11, 2012 | 05:40 PM
popeye47's Avatar
popeye47
Just the way its supposed to, straight up for permanently on and down to dim.
Old Sep 11, 2012 | 09:57 PM
alloro's Avatar
alloro
Then start with the simplest thing, check for a blown fuse. Maybe something shorted when you were swapping the switch. If all fuses are good, then I'd pull the switch out again to inspect the connector. There might be a splice right there where the interior light wire runs off to the GEM delay circuit. I think you'll be looking for an orange wire with a light green tracer.
natedog37
Aug 18, 2020 01:06 AM
Claybe
Jan 25, 2010 11:26 PM
Montana Workhorse
Jan 26, 2009 07:21 PM
Culvert
Mar 1, 2008 02:27 AM
Headviking
Aug 15, 2007 01:35 PM
