Just picked up a used 06 F350 SD. I have a question on how to get the light in the box of the truck to come on without having all the lights in the cab on.
Is there a switch that just turns this light on/off. Or is it just the 1 dimmer switch that turns on all interior lights aswell?
Consider using a diode. Then you can have it turn on with the interior lights, and also turn on with the new switch, but not backfeed the interior lights. Otherwise you would have to isolate the light from the interior.
I'm just going to wire it separate because I don't want it to come on everytime the interior lights are on. I only want it on when I turn on the switch.
