Dome light stays on?
Old Nov 16, 2016 | 01:52 PM
natedog37's Avatar
natedog37
Why the heck would my dome lights (front and back) stay on while I'm driving and when the truck is off KOEO and locked? It's not the reading lights, those I can turn on and off at the switch on the light, it's the lights in between them.
Old Nov 16, 2016 | 01:57 PM
P4IN COMM4NDO's Avatar
P4IN COMM4NDO
Not sure. Check the fuse for a short??? If it bothers you you could always pull the bulb out.
Old Nov 16, 2016 | 02:14 PM
thomabb's Avatar
thomabb
Switch inside one of the doors sticking?
Old Nov 16, 2016 | 02:17 PM
natedog37's Avatar
natedog37
Ugh, well...remember how there's no stupid questions? I must have rotated the dash dimmer switch to the on position, which turns on the dome lights. Thanks guys.
Old Nov 16, 2016 | 02:26 PM
thomabb's Avatar
thomabb
Funny, I was literally just commenting on another thread how we tend to jump ahead in our troubleshooting logic and tend to miss the simple things...
Old Nov 16, 2016 | 02:31 PM
ExPACamper's Avatar
ExPACamper
Hey, check your dome light switch, the dial next to your headlight switch on the dash.
Glad it was a simple one
Old Nov 16, 2016 | 02:59 PM
CampSpringsJohn's Avatar
CampSpringsJohn
Well, since it was brought up, there's a switch inside the door that activates the dome light. IF, you find out that a sticking switch is the problem, (and not the dimmer switch being turned on) you can usually fix it by spraying up inside the latch in the door with some PB Blaster with a straw, then open and close the door a few times.
Old Nov 16, 2016 | 03:28 PM
TerranE's Avatar
TerranE
Number 1 relay will leave your interior lights on.
Old Nov 16, 2016 | 03:49 PM
DaveP.'s Avatar
DaveP.
Stuck on door switch will trigger a Door Ajar warning while driving, but the dome lights will be out. The dome lights stay on longer with key off after closing the door with the stuck = on switch.
Another way to diagnose a door switch. If there's no Door Ajar warning while driving, it's not a door switch.
Old Nov 17, 2016 | 08:30 PM
P4IN COMM4NDO
Well you gave it the old college try
Just kidding. The easy problems are the nice ones to have.
Old Nov 18, 2016 | 07:35 AM
ExPACamper's Avatar
ExPACamper
FYI, AutoEnginuity can monitor the door ajar condition and tell you WHICH door (or liftgate window in the Excursion) is bad.
There has been more than one person come by my buddy's and offer $50 if he could tell them which door and fix it.
No $50 involved, but it did convince him to buy a copy of AE, after using mine for a while
Old Apr 15, 2019 | 07:14 AM
mfeijo's Avatar
mfeijo
Thanks!!!
Tell you what: I was here trying to figure which new gremlin was keeping my light on. I fixed a lot of electrical issues in the last month or so on my 05 F250, but having the light on and no door ajar alert was a new one. So I googled it, found your post, slapped my forehead, went on the truck and sure enough, the dimmer was all the way up!
Old Apr 15, 2019 | 09:15 AM
RA101725's Avatar
RA101725
Banned
I just replaced my passenger side door switch since it would act up for a couple days when it got wet. Try not to break the two plastic tabs that hold the wiring harness to the switch by using a long flat blade and a flashlight. That is the trickiest part since the plastic is old and brittle. I broke one of the tabs but the other one is holding it fine.
this helps illustrate:
Old Jun 21, 2019 | 10:08 PM
Chad Johnson's Avatar
Chad Johnson
My '03 F350 has the same problem it is due to the door ajar switch being stuck on the passenger door.
Old Aug 18, 2020 | 01:06 AM
Chance_Thomas's Avatar
Chance_Thomas
Sprayed some WD-40 in each door latch and shut the doors to make the dome lights to go out.
Philster
Nov 23, 2018 11:24 AM
cjben
Nov 27, 2015 10:32 AM
garmford
Mar 23, 2013 05:35 PM
Cwby
Jan 13, 2007 08:21 AM
FordPickup460
Nov 21, 2004 12:51 PM
