Another code thread.... need to know how to fix the problem
Old Sep 12, 2012 | 07:11 PM
F350-6's Avatar
F350-6
Originally Posted by JOHN2001
There is 2 relays, I have it hooked up right. No gpcm...
If you don't have a GPCM, why are you worried about GPCM fault codes? As I said before, ignore the codes. They're obviously not accurate.
Old Sep 12, 2012 | 08:43 PM
JOHN2001's Avatar
JOHN2001
If it doesn't have a gpcm why would it throw the code?
The main one I was worried was the gear one ratio code. I'll take your guys advice and ignore those ones and concentrate on the others which sounds like could be an easy fix thanks again
Old Sep 13, 2012 | 12:36 PM
CSIPSD's Avatar
CSIPSD
More then likely that reader at autozone was pulling bad codes, or changing them for some reason. If you have two relays, you dont have a GPCM.
Deep South
Oct 1, 2014 01:32 PM
mudmagnet63
Feb 14, 2014 12:28 PM
wthompson912
Nov 13, 2012 06:35 AM
azcoca
Aug 12, 2010 12:06 PM
triskit16
Oct 27, 2008 09:59 PM
