Cab Identification
Old Sep 9, 2012 | 02:32 PM
Tazmax 1975 High Boy's Avatar
Cab Identification
Need help identifying a cab I know it is a 1973 - 79 era. It is a cab that was in deal I did to get another high boy 3/4 ton chassis. The cab has a solid floor. Meaning that it does not have a bolt in trans. cover. It has not had a replacement floor or any repairs done to it, very solid rust free cab. There is no V I N on it to help and the doors are missing. Previous owner sold them. Every truck I have ever owned (and I only own Fords) 2WD, 4WD, Stick or Auto has had the bolt in trans cover. I am thinking of using it on my daily driver since the V I N plate is on the door of truck. Any ideas? Thanks.
Old Sep 9, 2012 | 02:38 PM
evam350's Avatar
evam350
Its from a 2wd
Does it have shoulder belts?
Old Sep 9, 2012 | 03:32 PM
dmt_73ford's Avatar
dmt_73ford
I've got a '73 2wd AT that has no removable trans cover
Old Sep 9, 2012 | 03:47 PM
jim collins's Avatar
jim collins
My 73 that came with a 3 speed column shift has a solid floor and a 79 i had that came with a C/6 auto transmission had a solid floor, Both 2/wheel drive. So I guess it depended on what kind of transmission came in them new maybe.
Old Sep 10, 2012 | 05:40 PM
Well that helps clear up the mystery. I was beginning to think it was a canadian built cab or something. Thanks for the info.
Old Sep 10, 2012 | 05:58 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Shoulder belts (straps) were an extra cost option 1973/76, became standard equipment in 1977.
1973/76: In the upper corners of the cabs are rubber plugs, pop 'em off, this is where the SEPARATE shoulder straps attach.
The R/L lap seat belts with shoulder straps have two buckles. One for the shoulder strap, one for the lap belt.
1977 and later: Shoulder belts incorporated with lap belts, have only one buckle per side and retract.
Old Oct 1, 2012 | 10:29 PM
Ok, from the information I have received it is most likely a1973-74 2wd. I will just use the removable trans. section in my cab to make a template for it and cut the floor and bolt in my cover.
Also how many posts do I need to be able to post a classified for a rolling chassis and and bunch of parts?
I appreciate the info.
Old Oct 1, 2012 | 10:56 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Another clue to it being a '73-'74 cab is to look at the firewall. In the center of the firewall, just below the cowl is an oval shaped rubber plug. '75-up didn't have it.
fsbronco1989
Sep 15, 2015 08:56 PM
nickelndime79
Oct 25, 2012 01:04 PM
BigMightySam5600
Oct 6, 2012 07:07 PM
FX5
Mar 13, 2010 11:10 AM
V MAN
13
Nov 16, 2005 09:46 AM
