Ford Manual Timing Instructions??
Old Sep 7, 2012 | 06:14 PM
bduemig's Avatar
bduemig
I recently purchased a service manual on CD. I am getting ready to change the IP so I printed all the pages dealing with the IP change. I also have a timing meter so i printed out the dynamic timing procedure as well. Here is the question.
After connecting the timing meter, the instructions (step 5) says, "With Transmission in Neutral and rear wheels off the ground, start engine. ... set engine to 2000 RPM with no accessory load ...
Question - Why do the wheels have to be off the ground and why Neutral and not park? Does that make a difference?
Old Sep 7, 2012 | 06:18 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
i time mine in park.try it both ways and let us know if you come up with two different timing readings lol.
make sure the instructions you have, don't involve removing anything but the timing gear cover plate.all you want to remove are the two bolts under that.remove the whole top assembly,like some instructions say to do,and you'd wish you didn't.
Old Sep 7, 2012 | 06:36 PM
bduemig's Avatar
bduemig
Why raise the rear wheels? That was stranger than being in neutral. The neutral instruction could be there for manual transmissions.
I've already checked that and it does not have you remove the whole gear housing; just the cover over the pump drive gear.
Old Sep 7, 2012 | 06:38 PM
FORDF250HDXLT
likely for safety reasons.if she slid into gear while your standing out front revving her up to 2k rpm with the throttle linkage,it could be the end of ya.
Old Sep 7, 2012 | 06:40 PM
bduemig's Avatar
bduemig
Ahhh! Good point!!
Clay frost
Mar 1, 2014 10:40 PM
rdweathers
Mar 31, 2011 08:56 AM
newr
Feb 23, 2010 08:24 PM
zero 2
20
Nov 24, 2006 12:14 PM
KJKozak2
Sep 10, 2003 01:05 PM
