Sponsored by: Real Truck
Problem with 4x4
Old Sep 5, 2012 | 07:43 PM
76250_4x4's Avatar
76250_4x4
Problem with 4x4
guys the truck is a 2002 f350 powerstroke, auto trans, electric t case. I am not getting any action from the t case shift motor however when i test it on my bench it works fine. I even tested the sensor for the light on the side of the motor and it lights up for 4x4 and 4 low. I tested the switch on the dash, the reistance is correct for all 3 ranges. I also switched out the 4x4 relays by the master cylinder and checked every fuse. Thinking i have a bad gem module. Give me some hints guys Thanks everybody
Old Sep 5, 2012 | 08:32 PM
madsonp's Avatar
madsonp
I had some issues with my old 99 Expedition. Here's a thread I wrote on what I found on mine, might be something for you to look at.
https://www.ford-trucks.com/forums/8...ow-issues.html
Old Sep 5, 2012 | 09:34 PM
tomspear's Avatar
tomspear
My problem was not the same as yours because my instrument panel lights for 4x4 and 4x4 Low would not come on (2000 F250). The problem turned out to be 2 or 3 pins were pushed back slightly in the 6 pin plug going to the motor on the transfer case.
Everything worked fine after reseating the pins by pushing them back in from the rear.
It took quite a long time to figure out that problem, but I learned a lot about the 4x4 ESOF in the process.
Good luck.
4x41977
2004 - 2008 F150
Mar 7, 2017 06:55 PM
imabaka
Jul 26, 2010 09:01 PM
findr
1983 - 2012 Ranger & B-Series
Feb 13, 2004 06:01 AM
scotts88bronco
1978 - 1996 Big Bronco
Jan 29, 2004 07:47 PM
Dwarwick
Offroad & 4x4
Jul 21, 2002 01:02 AM
