do i need more fuel
Old Sep 4, 2012 | 03:21 PM
jhendry's Avatar
jhendry
do i need more fuel
I have a prob. With truck not wanting to rev past 2500rpm while pulling boat motor feels good up til then and falls on its face truck is a 92 f150 5.0 I have 1.7 roxkers timing advanced 15* ,61mm throttle body and 2in upper intake spacer.
Old Sep 4, 2012 | 04:36 PM
BigBlueOx's Avatar
BigBlueOx
I highly doubt your peaking the delivery of your trucks fuel system.
It sounds like you have a mash of mongrel parts on there and that may be part of your problem.
Do you have the ability to check fuel pressure?
Does it run fine and rev past 2500 without a boat?
Old Sep 4, 2012 | 06:00 PM
jhendry's Avatar
jhendry
Truck runs good and runs better with vacuum off fuel regulator I just don't think its gettin enough
Old Sep 4, 2012 | 06:10 PM
danr1's Avatar
danr1
As stated check the fuel pressure, you wouldn't need "more fuel" then the system designed to deliver stock. Other then of course to correct for a failing fuel pump, partially clogged fuel filter or faulty FPR. Maybe FMU, faulty check valve wide open returning fuel to both tanks, fpr not able to maintain.
Old Sep 4, 2012 | 09:11 PM
Truckin Bob's Avatar
Truckin Bob
As silly as this sounds..........
Is the spout connector there and firmly snapped in ????
Just a thought,
Bob
Old Sep 5, 2012 | 05:50 AM
jhendry's Avatar
jhendry
Yeah the spout is in and taped .I took the vacuum off and the truck will rev to 4000 rpm before shift so I'm thinking its not getin enough presure the fpr isn't that old. Why does it run so good like this fuel pressure Idk don't have gauge
Old Sep 5, 2012 | 07:43 AM
rla2005's Avatar
rla2005
You can rent one from Auto Zone, Advance, etc.
Old Sep 5, 2012 | 12:40 PM
Truckin Bob
That statement brings concern.
It almost sounds like the spout connector is broken/damaged and it's being held in place by tape.
Poor or non-existant connection ????
Bob
MA Berlin
Apr 28, 2016 12:34 PM
AMDFX8150
Jun 14, 2015 11:20 AM
Redneckfordf2502002
16
Jan 8, 2014 05:04 PM
javi2001
Dec 30, 2007 07:54 PM
kmerk
Jun 25, 2007 11:51 AM
