Building A 460 - Much Help Needed!
Old Sep 6, 2012 | 12:07 AM
  #46
keiths78f150's Avatar
keiths78f150
I figured all I will need is 95cc for the build I am doing. Somewhere around a 9.5:1 compression.
Old Sep 6, 2012 | 08:06 AM
  #47
elgemcdlf's Avatar
elgemcdlf
You won't get 9.5:1 with 95cc heads unless you deck the block, run higher compression pistons for your block, both or some combination that will increase compression. Your compression should be something like 8:1 with (I think) 93cc chambers. 1st you will be increasing your volume by moving to 95cc chambers which will lower your compression unless you do something to compensate for it. If it were me & I am not saying buy the Edelbrock heads, I would buy the smaller chambers & you still will not be at 9.5:1 but at least quite a bit closer. The smaller chamber more closely resembles the early heads that are the good cast heads. This is assuming the heads are the same with exception of chamber size.
Old Sep 6, 2012 | 08:09 AM
  #48
keiths78f150
I was planning with higher compression pistons., but I may just get the block decked, or may get the smaller heads. All depends on the condition of the internals of the motor I buy I guess. We will see. Scott pointed me toward a great shop here local so when it's time, the machine shop and I can figure out what I need to do to get my results.
Old Sep 6, 2012 | 09:18 AM
  #49
elgemcdlf's Avatar
elgemcdlf
Great. I think you will be far happier with the shop Scott recommended than the 1 you had listed assuming they are different. Of course without using both you will never know
Scott's website
Messed up, he is in WA not MI. I talk with a guy from MI that is also pretty knowledgeable on these engines. I would also bet the expense may be lower with this new shop. He sent you to someone who knows the 385 series so they won't waste any moves.
Old Sep 6, 2012 | 11:16 AM
  #50
keiths78f150
Yea I agree, thanks for the help man.
Old Sep 9, 2012 | 10:14 PM
  #51
lippsgarage's Avatar
lippsgarage
Keep us updated... I'm not far from you, just outside of Springfield. I'm shooting for 500-600 HP myself, selling my Mustang (anyone interested lol) so this is my new toy. I like the aluminum for the weight reduction as well, and cost for me is worth it between machining my current as well as rebuilding the stock, besides I don,t think I have the good heads. Anyway, if nothing else its a new adventure :-)
Old Sep 9, 2012 | 11:07 PM
  #52
keiths78f150
All my updates from now on will be in my build thread which is in my signature.
Old Sep 9, 2012 | 11:18 PM
  #53
jgavac's Avatar
jgavac
The RPM air gap is a good manifold. I run it on mine, but with only a dinky 650 carb
Old Sep 9, 2012 | 11:20 PM
  #54
keiths78f150
I have had that manifold recommended to me by multiple people. Its on my list haha I will obviously be using a 750 or 800 carb though haha
Old Sep 9, 2012 | 11:21 PM
  #55
jgavac's Avatar
jgavac
If I had a few hundred laying around I would upgrade to something like a 750 or 780 double pumper and REALLY kill my fuel economy
Old Sep 9, 2012 | 11:22 PM
  #56
keiths78f150
Who needs miles per gallon when we can measure gallons per mile?
Old Sep 9, 2012 | 11:25 PM
  #57
jgavac's Avatar
jgavac
amen to that
william16339
Aug 24, 2015 12:46 PM
caleb_ford
13
Oct 14, 2011 06:19 PM
4x4jedi
Jan 26, 2010 11:52 AM
ManfredVonRichtofen
Nov 16, 2009 09:43 PM
ROUSHRACING
Sep 28, 2001 11:06 AM
