aluminum heads from edelbrock don't need a port and polish they are bad *** straight out of the box they are pretty sweet but they aren't cheap they are in the $1000 + range depends on how hot you wanna go
i would't know how much it would cost to have them ported and polished i did it myself it cost me less than a $100 bill since i already had dremel tool just had some guidance from an old hot rodder/tranny builder/motor building/brother in laws dad/guru lol he taught me alot and all it took was time and patience
I know that's quite a ways away but there should be 1 in your area. Again the guys at the 460 site will be able to point you to a good builder in St. Louis.
Well I got a hold of Scott, and like you said he is going to point me to a good shop around my area. He said "It is not cost effective to ship a block here for machine work. There are competent machine shops with in driving distance from you that we can help match you with."
Then he gave me an idea of what I would need to match my 400-450hp goal. Real good guy.
...Most popular thing I've heard is get a good set of aluminum heads... they are the biggest limiting factor with these motors (correct me if I'm wrong)....
You are both correct & incorrect at the same time. The largest problem with the 385 series engine is exhaust breathing & it does start in the head. I have a set of C9VE-A heads on my engine & they can be taken up to somewhere between 650 & 850 hp. If you are building anything more serious than that then yes good aluminum heads would be in order but you can get good flow out of the correct casting numbered cast heads. You have to back that up with a free flowing exhaust (as free flowing as you can get). Bite the bullet & buy some headers with 1 7/8" primaries. Your pipe D. will depending on your hp output. Aluminum Edelbrock heads heads start at $680 each plus new pushrods & head bolts. They also state they are good for 550+ hp. I can do better than that with my cast heads.
I dont want to be close to 550HP. I plan on having long tube headers. The heads I like are the Performer RPM 460. Gonna match those with a RPM Air Gap 460 intake and a Thunder Series AVS 800 cfm carb. This is edelbrocks little "power package" but I had the carb and intake already suggested to me by mike0o0o0o
Go to 460 forum and search 450 hp build and you will get information on what you need to do.
Be carful or you will go over your 450 hp target. It doesn't take much to get 450 hp out of these engines and it can be as simple as a timing set/cam/head/intake/carb combination and you will be there.
The problem happens when you don't plan on ending up at 650 hp and the components you used won't handle that much. It would be like deciding to use nitros after the fact but you didn't use forged pistons, it will be a mess.
I myself am shooting for 600 - 650 hp so I am using parts that will take the abuse.
I have a video at home that is very good. I will get the name of it when I get home and let you know.
Excellent advice. You do not need aluminum heads to hit 450. You can get to 450 with almost nothing at all after all you are starting with 460 cid. They have complete proven build recipes over at the 460 site for whatever hp range you desire. If 450 is all you want you can do it for way less than the parts you say you want to buy. I am shooting for 650 when I actually build mine. I am 375-400 now.
The main reason I would like aluminum heads is for the lighter weight. No need to have stupid heavy heads when I could shed a few pounds. Money isn't an option.
Well as has been said too many times the guys at 460.com will be able to tell you which aluminum heads you want. I know there is a set out there they say are worse than having the cast heads. Don't remember what heads they are. My cast heads will do what I want them to do.
I have plenty of money, so I can get what I want. Doesn't mean I will spend $2300 on a set of heads. The motor is going into a street queen pickup. It will get babied. When I want to drive fast, I drive my harley or my mustang. This truck was purchased because I love the trucks and wanted to learn how to work on cars. I would be happy with 375-450hp. Everything I have chosen so far, has been set for a mild build. I dont want anything crazy, just an improvement on the 351m, which wont be hard.
