1966 - 1977 Early Broncos
1968 Bronco Vin number
Old May 15, 2003 | 12:36 AM
madbrit's Avatar
madbrit
I have just bought a 1968 Bronco from an old guy who handed me the title. I cannot find where the vin number is on the vehicle. I did an internet search and found that the '67 has it on the cowl, but the '68 has it in the glove box. All I found in there was a metal sorta clip a bit like a money clip, which was on the left side of the glove box.
Is the vin repeated on the frame somewhere? The vehicle is from out of State so I have to have it inspected before registering it.
Thanks for any help anyone can send.
Peter.
Old May 15, 2003 | 07:56 PM
steve83's Avatar
steve83
Look at this one. The last pic is from the inside of the glove box. The other one with the VIN is from the door jamb.
Old May 15, 2003 | 10:54 PM
RCrawler's Avatar
RCrawler
The glovebox door is the most likely, although easily tampered with. 66 only had them on one of the kick panels, I believe drivers side. The earliest I've seen the stickers inside the door jamb is early 71.
But, there is a number stamped on the frame. Most of the time, it can be found on the passenger side frame rail at the front just behind the coil tower and shock mounting. I have seen them on the top of the frame and on the side. If you use a wire brush on that area, you should be able to find it.
I have also seen them stamped elsewhere on the frame in several places.
Jason
MGannaway
Large Truck
Jan 23, 2014 11:09 AM
jxnslotcar
Apr 23, 2013 12:42 PM
'53 F100
Texas Chapter
Sep 24, 2012 12:48 PM
mikes56
Apr 25, 2009 04:17 AM
Flaflathead
Oct 5, 2003 10:31 PM
