Radiator replace
Old Sep 2, 2012 | 03:12 PM
AWC's Avatar
AWC
Radiator replace
97 4.0. I need to replace my Rad. Do I need to remove the Fan clutch to remove the Radiator? I'm hoping to just loosen the shroud & pull the Radiator.
Old Sep 2, 2012 | 03:55 PM
KhanTyranitar's Avatar
KhanTyranitar
You can just remove the shroud and pull it. Its easier with everything out of the way however, but removing the fan/clutch requires special tools. And its actually not easier unless the clutch decides it wants to come off. Just be carefull going in with the new rad that you don't damage it.
Old Sep 4, 2012 | 11:08 AM
2002exPSD's Avatar
2002exPSD
Easiest way is cut a slit in the bottom of your fan shroud in the middle. Then just pull the shroud off like a c-clip. Getting the rad in and out is pretty close but it fits.
Old Sep 8, 2012 | 01:49 PM
AWC's Avatar
AWC
There are Two clips on the side of the Rad holding the shroud on/in. Can the shroud be lifted out of the clips without removing the fan clutch? It doesn't look like it can be done. Can you elaborate a little more on removing the Rad without having to remove the fan clutch.
Derfus
May 28, 2012 01:22 AM
wreckinball
Jan 26, 2010 04:43 PM
smileyoppossum
Jun 16, 2009 07:31 PM
wolftan
Aug 1, 2006 11:36 PM
Irv
May 21, 2003 05:06 PM
