91 explorer radiator fan replacement?
Old May 21, 2003 | 12:20 PM
Irv's Avatar
Irv
How do you replace the radiator fan(plastic) with out removing the water pump ? Irv
Old May 21, 2003 | 12:25 PM
Dialtone's Avatar
Dialtone
Unscrew the fan clutch from the water pump snout (it is left hand threads). You may need to get a special tool to remove it. AutoZone rents the set for a nominal price. You may also need to remove the fan shroud to get the clutch/fan assembly out. Then remove the bolts holding the fan to the clutch assembly. Install is the reverse.
Dialtone
Old May 21, 2003 | 05:06 PM
Maniak's Avatar
Maniak
I just removed the fan clutch on our 92 and on the Fan Shroud it said "right hand threads"..
If it is right hand threads, it is lefty loosen (when standing at the front of the truck)..
If its left hand threads, is is righty loosen..
Double check before you try to take it off.. (btw.. I have 2 books for our X, and one said left threads, the other said right threads).
~Mark
SS70ElCaminoOwner
Mar 6, 2016 10:10 AM
Irving88
18
Mar 27, 2015 07:49 AM
kidoo
Apr 14, 2014 06:06 PM
rog2000
Feb 22, 2014 02:46 PM
rickeylipham
Apr 13, 2008 10:01 PM
