Sponsored by: Kumho
ABS Code readers
Old Sep 1, 2012 | 02:47 PM
bashby's Avatar
bashby
ABS Code readers
I have been thinking about getting a code reader of my own, I make a lot of trips to Autozone for side jobs. I have a job to do on a 98 Ram3500, it has an abs light on. I dont have a lot of money to spend, so price is an issue. I found this one: Amazon.com: OTC 9450 Bilingual OBD II Scan Tool, ABS and Airbag (SRS) Code Reader: Automotive
Any other reccomendations for a code reader that will do ABS?
Old Sep 13, 2012 | 06:52 PM
Muffinman's Avatar
Muffinman
Just use the jumper wire in the harness under the dash, You ground it while the ABS light is on and it will flash the fault code. Once you have that code you can start to track the problem down. Most the damn time some DA used a screw driver to push the front brake pads apart, without opening the bleeder valve, this forced the fluid backwards through the system and screws it up. You might check all your light bulbs including the 3rd eye. they all must work or the ABS system kicks on a fault.
Old Sep 17, 2012 | 06:48 AM
bashby's Avatar
bashby
I did some searching and couldnt find how to retrieve abs codes manually on a 98 Dodge. Do you know for sure this truck has that capability?
Old Sep 17, 2012 | 07:27 AM
Lazy K's Avatar
Lazy K
Not an expert but the grounding of the diagnostic connector only works for trucks with RABS (called RWAL by GM). For full 4 wheel ABS you need an ABS enabled scanner. You need to find out if that Dodge is RABS or full ABS.
Old Sep 17, 2012 | 09:07 AM
bashby's Avatar
bashby
It has 4 wheel abs.
Old Sep 17, 2012 | 01:50 PM
Lazy K's Avatar
Lazy K
Then you need a scanner. Would be interested to know which one you finally decide to buy.
redman84
Oct 20, 2011 03:40 PM
kjester
15
Mar 17, 2011 02:31 PM
dennyo
Feb 11, 2009 09:49 AM
McGunner
1997 - 2003 F150
Apr 9, 2005 05:30 AM
maurizio
1997 - 2003 F150
Nov 26, 2003 08:20 AM
