Sponsored by: Auxito
Abs self testing kit
Old Nov 25, 2003 | 08:39 PM
maurizio's Avatar
maurizio
anybody ver heard of this?
DIY site says that it is possible to retreive ABS codes with this simple device. it hooks up in the ABs module and makes the ABS light on the dash blink.
for instance two blinks a pause the 3 bilinks will determine a 23 as a code # to referr to.
if anyone has info regarding this please let me know.
P.s. I already checked with Pep boys, Autoz. and Advance.
They do not even carry any scanner for ABS
Old Nov 26, 2003 | 08:20 AM
Racerguy's Avatar
Racerguy
If the truck has rear wheel ABS you can count the flashes to get a code by simply grounding a wire under the dash. With 4 wheel ABS you need a scan tool.
