White plugs
Old Aug 31, 2012 | 08:58 PM
rangergirl94's Avatar
rangergirl94
White plugs
I have a 94 ranger 4.0 I noticed the spark plugs are turning white haynes man says could be intake manifold vac leaks I see gasket problems are common so im just gonna change them for giggles it also has the 4.0 famous tick can I fix this by changing pushrods??
Old Sep 1, 2012 | 03:28 AM
xlt4wd90's Avatar
xlt4wd90
If you have such a leak in the intake manifold as to cause the spark plugs to go white, the engine would be running badly. And you would trigger a check engine light from the engine computer.
I hear that the ticking noise is from the rocker arm wear due to insufficient lubrication getting to the tip area. The difference in length is very small, so I don't know if you can get pushrods in such small incremental differences.
I seem to recall that the old Cologne engines may have adjustable cups in the rocker arms, but I don't know if the more recent versions have them.
drumrooster
1997 - 2003 F150
Mar 7, 2016 06:14 AM
jlande
Crossovers
Mar 4, 2012 09:55 PM
Andrew_Dugas
1983 - 2012 Ranger & B-Series
Sep 15, 2006 03:50 PM
rangercobrar
Dec 8, 2004 08:53 AM
MACS RANGER
Mar 13, 2002 10:00 AM
