Sponsored by: Auxito
replacing plugs???
Old Mar 1, 2016 | 10:28 PM
drumrooster's Avatar
drumrooster
replacing plugs???
2000 V6 f150 just got it I"e read all the bad storys about plugs breaking off in the head when u try to change them?? is this an issue with this year and motro also??the V6?
thought I"d replace the wires and plugs
Old Mar 1, 2016 | 11:26 PM
Sam I Am's Avatar
Sam I Am
The V6 is a completely different engine design from the modular V8 & V10. The 4.2 V6 does not have any spark plug issues.
The modular engines are overhead cam and the spark plugs sit in a deep well.
The V6 spark plugs are just hanging out by the exhaust manifold like most older engines.
The spark plug problems occur because on some years there were too few threads holding in the spark plug and also the torque spec was too low. The coil on plug configuration further complicated the issue because owners were even less likely to pull off all the COPs and retorque all the spark plugs. Then on 3 valve 5.4s the spark plugs used a different 2 piece design that can fall apart upon extraction if left in the engine too long.
The 4.2 V6 is fine on spark plugs. The biggest problem I know of on mine has been the intake isolator bolts needing replaced. It is a lot of work, but not especially difficult. Otherwise, keep oil in it, keep it tuned up, and drive the wheels off it.
Make sure you get the wires in the right place on the coil and to the correct cylinder.
The arrow points to the front.
Old Mar 2, 2016 | 01:24 AM
drumrooster
Thanks a bunch that helps a lot. .im getting a miss now an then and after I changed the oil It's been making a slight ticking sound? I used 5w30..would that be to heavy? Or could it be the intake leeking? Just got it so gotta look at it this weekend.
Old Mar 2, 2016 | 08:05 PM
Todd Rasmussen's Avatar
Todd Rasmussen
I would look at intake , and exhaust manifold possible, leak, does it quite a bit when it warms up, could be exhaust manifold
Old Mar 2, 2016 | 08:47 PM
drumrooster
Ok gonna check it this weekend..will let u know thanks
Old Mar 7, 2016 | 06:14 AM
drumrooster
tick...
well I used my little sniffer that amplifys sound on it this weekend at start up,,the ticks not coming from the valve covers or exhaust..when I put it on one of the injectors I can hear the tick strong?? I'm thinking it s just the injectors?..
msasteeler
6.2L V8
13
Nov 27, 2019 09:42 AM
powerstroker100
May 11, 2016 06:27 PM
markfh11q
1983 - 2012 Ranger & B-Series
Aug 13, 2007 07:46 PM
makeoutmusic
Jun 29, 2007 09:12 PM
robbiecox6
Jul 11, 2006 06:12 AM
