smoke??
Old Aug 31, 2012 | 05:43 PM
inquistiveone's Avatar
inquistiveone
smoke??
I'm new to diesels so I'm wondering....should I be concerned about
white fumes from the tailpipe?
Old Aug 31, 2012 | 05:51 PM
cartmanea's Avatar
cartmanea
Yes you should. They are usually caused by a leaking egr cooler (smell like coolant) or a cracked injector tip leaking excess fuel (smells like fuel).
Old Aug 31, 2012 | 05:54 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Yes. Under normal conditions you shouldn't notice anything major from the tailpipe. If its a small amount and depending on weather conditions, it could be condensation in the exhaust evaporating as the exhaust warms up. If its a significant amount or you see it when the truck is warm, it could be coolant or fuel. Try to get a whiff of it, the smell will be obvious.
Old Aug 31, 2012 | 06:14 PM
BLADE35's Avatar
BLADE35
check coolant leval
Old Sep 1, 2012 | 01:17 AM
lupuseven's Avatar
lupuseven
to double check the odor just cover the pipe with your hand for a couple of secs and smell your hand.
like they said if it smells like:
sweet = coolant = egr cooler(usualy)
fuel = injector probs
Good luck!
429poweredf350
Jun 20, 2014 11:13 PM
alexmartin33
Aug 9, 2011 02:44 PM
cricketmowing
Feb 22, 2010 05:09 PM
fatrhino
17
Aug 27, 2008 07:35 AM
1994diesel
Jul 20, 2008 09:00 PM
