Yesterday my truck started skipping-shuttering. No dash lights came on.
My tools were in the other truck, so i decided to head towards home (about 10 mikes and i got home). I was moving slowly when it started. I was in town so my speed was limited. It did not quit running till i shut it off at home.
I am thinking UVCH for drivers side (replaced passengers side a couple of years ago-symptoms then were worse).
I have a Superchips tool but have never tried to use it to troubleshoot. I am sure it has limited capability.
Usually the issues with the UVCH will be accompanied by a SES light, and the code P1316. But if you haven't done the 50 cent mod to that side it is good preventative maintenance.
Recent fuel stop? Clogged fuel filters? I would ask what the fuel level is but should be fine since your sig says Hutch mod, unless the pickup fell off, or the duckbill cracked.
I have a 01 7.3 and i was driving down the road lose all power and it ran like crap change fuel filer and cps censor had a histor code for cps cleared code change cps censor ran good for 25u miles done same thing again could this be bad fuel or what help please
