Modular V10 (6.8l)
IAC issues no dtc
Old Aug 29, 2012 | 08:29 PM
britt's Avatar
britt
IAC issues no dtc
Guys...my 2000 v-10 sd is stalling out on me. It started a while back occasionally it would die right after start up, once in a while. now its up to several times a day and even when stopped at a red light. I suspect its the iac valve...so I pulled it last week and cleaned the carbon off. you know the feelng when you THINK you've fixed it and then, damn it does it again... will the IAC throw a code ? ive cleaned the maf as well . I have a new motorcraft IAC valve , but wanted to double check with you guys before I tore into it. Thanks
Old Aug 30, 2012 | 12:10 AM
Monster-4's Avatar
Monster-4
Bad IAC will not set a DTC as far as I know. Can you get the truck to start and idle by using the accelerator?
Old Aug 30, 2012 | 12:21 AM
khadma's Avatar
khadma
Carpenter Local 745
Air leak after MAF can cause issue.
Old Aug 30, 2012 | 05:50 AM
britt's Avatar
britt
guys...thanks... yes i can hold slight pedal and shift into drive and it will stay running.
how to check for air leak after MAF ?
sorry so short...trying to get to work...thanks
Old Aug 30, 2012 | 09:21 PM
mikeismadness's Avatar
mikeismadness
The IAC will not cause a CEL or DTC. Sounds bad to me. Cleaning them doesn't always do the trick. Replace it since you have it.
Old Aug 31, 2012 | 06:39 AM
TrdLtly's Avatar
TrdLtly
TreadLightly
If the new IAC doesn't fix it then.... I would suspect the COP's. You could have one or two failing although usually you would only see it stall in gear and not right after start up. IAC, vacuum, MAF are about it for start up.
Old Aug 31, 2012 | 08:45 AM
Monster-4's Avatar
Monster-4
As other have said I would start with replacing the IAC since you can get it to start with some accelerator pedal input.
Old Sep 2, 2012 | 06:27 PM
mikeismadness
And while your at it pick up some MAF cleaner and carb cleaner. Clean the MAF sensor and clean the throttle body. Important maintainence that people overlook
scottss80
Escape & Escape Hybrid
54
Mar 20, 2010 01:15 PM
Elmo154
May 26, 2009 04:36 PM
bgirard78
1983 - 2012 Ranger & B-Series
Nov 12, 2007 05:25 PM
fordtruckman11
1997 - 2003 F150
Jun 5, 2007 10:26 PM
50th ann
1997 - 2003 F150
Sep 26, 2005 08:56 AM
