Stumbling after quick stop
Old May 25, 2009 | 07:43 AM
Elmo154's Avatar
Elmo154
My 2000 EX v10 has developed a slight rough idle and a significant but intemitent stumble after a quick stop. If I put it in neutral it smooths out and is then ok. Seems to run fine under power on both local roads and highways. Have 150k miles. Any ideas?
Old May 25, 2009 | 03:37 PM
Monsta's Avatar
Monsta
Sit. Stay.
Signs that the Idle Air Control (IAC) valve needs a little attention. Also points to the MAss Airflo Sensor (MAF) that may need cleaning as well.
I would do a search in the v10 forum both and you'll find many links on how to clean/service both the IAC and the MAF.
Old May 26, 2009 | 04:36 PM
Elmo154's Avatar
Elmo154
Have already replaced the MAF. Took a shot at IAC today but screws would not budge. Any ideas on how to remove screws without stipping heads?
