Trans Overheat light
Old Aug 28, 2012 | 11:44 PM
utahtom's Avatar
utahtom
2003 Explorer with 4.6 V8, "transmission overheat" light keeps illuminating after the transmission was replaced with a reman unit. The manufacturer and installer are standing behind their work but are stumped... The trans cooler was tested for backpressure etc and checked out good. The light comes on after the vehicle is driven about 15-20 miles.
Any suggestions and/or input is greatly appreciated
Old Aug 29, 2012 | 09:32 AM
KhanTyranitar's Avatar
KhanTyranitar
Heat is generated when a transmission slips. In my experience, reman units are usually garabage. They are built on a budget, and only replace the parts that the builder deemed necessary. Apparently they missed or skipped something. Thats why I have always had my transmissions rebuilt by a qualified shop as opposed to swapping in a trans that came off someone elses ride, which may or may not have had its original failure repaired.
Old Aug 29, 2012 | 06:56 PM
jk080's Avatar
jk080
Transmission Rebuilder
Has the transmission temperature actually been monitored with a with a gauge? The temp sensor itself could be at fault.
Old Aug 30, 2012 | 05:36 PM
utahtom's Avatar
utahtom
The high tranny temps have been confirmed with specific temps through a monitor. They have ruled out a chafed wire or bad sensor. The new/remanufactured tranny seems to overheat when the vehicle is operated for longer than 30-40 minutes. The trans cooler was flushed and tested prior to installing the reman tranny. Nobody is sure why there are high temps although Khan definitely made a good point.
Old Aug 30, 2012 | 05:48 PM
KhanTyranitar
It could the the torque converter is either slipping or not engaging. A torque converter generates a lot of heat.
edited, heat not money
Old Aug 30, 2012 | 06:05 PM
utahtom's Avatar
utahtom
Originally Posted by KhanTyranitar
It could the the torque converter is either slipping or not engaging. A torque converter generates a lot of money.
And the torque converter is the exact area that we've had problems in the past with noises and engaging issues.
Old Aug 30, 2012 | 11:26 PM
KhanTyranitar
You can get heavy duty torque converters with larger friction surfaces, brazed fins, and torrington bearings. A better torque converter should help. If there is a problem in the valve body for the engagement solenoid, you can get a low pressure condition, and the hydraulic circuit will not fully pressurize. Low pressure can cause slipping.
Mike Norwood
13
Oct 29, 2009 10:07 AM
Chuck Sowa
Jul 14, 2008 07:06 PM
STROKIN'IT7.3
Mar 6, 2008 07:58 AM
schmity
26
Sep 21, 2006 06:06 AM
cjcathey2002
Apr 29, 2005 09:56 AM
