07 6.0 no start
Old Aug 31, 2012 | 02:45 PM
BLADE35's Avatar
BLADE35
ok here is a Pic just keep in mind this from an 03 and yours is an 07 so the IPR will be in same spot
Just your 07 wont have ICP in the HPOP Cover
You might be able to repair the IPR Pigtail without turbo removal
here is the pic remember your will be little diff you will ONLY Have IPR in the HPOP Cover
this with the Turbo OUT the IPR is the one closest one to Front of truck
Old Aug 31, 2012 | 02:51 PM
BLADE35's Avatar
BLADE35
more pics
more info here
Old Aug 31, 2012 | 03:06 PM
17fordguy's Avatar
17fordguy
could it be in a worse spot to get to? ok ill go check it out thanks guys.
Old Aug 31, 2012 | 03:34 PM
BLADE35's Avatar
BLADE35
Yes LOL
A Lifter is the Absolute Worst
Old Aug 31, 2012 | 06:35 PM
cheezit's Avatar
cheezit
Originally Posted by BLADE35
Cheezit is replacing the IPR connector the Normal problem with this DTC
yup has fixed everyone I have had. cut harness as far back as new pigtail will let you.
Old Aug 31, 2012 | 07:05 PM
BLADE35's Avatar
BLADE35
Thanks for the Info Cheezit
First part# is FORD second part# Is INTERNATIONAL
<TABLE style="WIDTH: 740pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=987><COLGROUP><COL style="WIDTH: 221pt; mso-width-source: userset; mso-width-alt: 10788" width=295><COL style="WIDTH: 12pt; mso-width-source: userset; mso-width-alt: 585" width=16><COL style="WIDTH: 110pt; mso-width-source: userset; mso-width-alt: 5376" width=147><COL style="WIDTH: 95pt; mso-width-source: userset; mso-width-alt: 4608" width=126><COL style="WIDTH: 302pt; mso-width-source: userset; mso-width-alt: 14738" width=403><TBODY><TR style="HEIGHT: 22.5pt" height=30><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: #ccffcc; WIDTH: 221pt; HEIGHT: 22.5pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl68 height=30 width=295 align=left>IPR pigtail (to use to command the IPR valve closed)
for air testing the HPO system
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: #ccffcc; WIDTH: 12pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl69 width=16></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: #ccffcc; WIDTH: 110pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl67 width=147>6E7Z-12A690-DA</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: #ccffcc; WIDTH: 95pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl66 width=126 align=left>1875204C91</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 302pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" width=403 align=left></TD></TR></TBODY></TABLE>
Old Aug 31, 2012 | 09:56 PM
17fordguy's Avatar
17fordguy
you guys are awesome. haven't gotten the part yet have been driving truck all day with no issue. finally got a scanguage trying to be creative on were to mount it think i figured it out though then just got to program it. working on installing my oil and trans heaters for winter right now. Also the guy at Napa recommended a trickle charger over a heater pad for the batteries but said due to how the battery setup was in this truck was unsure of how i should hook it up to get a good charge to both battery's. any suggestions on this?
Old Sep 1, 2012 | 08:51 PM
17fordguy's Avatar
17fordguy
yep definatly ther plug didnt want to start a few minutes ago wiggled the plug a bit and fired right up.
Old Sep 1, 2012 | 09:19 PM
Fal-308-Win's Avatar
Fal-308-Win
Benny, Cheezit, way to go, that's what I like about you
Old Sep 1, 2012 | 09:42 PM
BLADE35's Avatar
BLADE35
Cheezit Hit a Home Run on that one
I was undecided if it was the Valve or wiring I knew it was one or the other
Old Sep 1, 2012 | 09:53 PM
17fordguy's Avatar
17fordguy
five years on this site and countless amount of money saved thanks to you guys.
Old Sep 1, 2012 | 10:29 PM
17fordguy's Avatar
17fordguy
Rep sent to both cheezit and blade for the assistance on this.
Old Sep 2, 2012 | 09:19 AM
  #28
cheezit's Avatar
cheezit
Thank you.
Old Sep 2, 2012 | 01:38 PM
  #29
BLADE35's Avatar
BLADE35
Thanks for post outcome it helps others
I know it can be frustraighting for others to search an issue find a thread with same stuff going on come to the end with no final answer
sent some reps back at ya
john8807
Jun 2, 2016 08:51 AM
jmaskew
Nov 10, 2015 03:56 AM
BRay09
Jul 7, 2015 05:27 PM
hink10
Aug 24, 2013 11:49 PM
lexasgs400
Oct 6, 2009 05:30 PM
