I'm gathering the following parts with the plan to have v-codes up front and b-codes (non-modified) with 3.5" blocks in the rear.
Can anyone tell me the part numbers for the front ubolts, rear ubolts, and nuts? I plan to place an order to Tousley as soon as I can find the right parts. I've been digging through old threads forever but keep coming up dry....
Front V Code 2C3Z-5310-HA
Rear B Code 3C3Z-5560-CB
Left Side 3.5" Tapered Block F81Z-5598-FA
Right Side 3.5" Tapered Block F81Z-5598-GA
Bilstein Front Shock BE5-2818
Bilstein Rear Shock BE5-6209
Hellwig Rear Sway Bar
I've seen all those other threads, but I haven't seen anyone report back that those part numbers work for the un-modified b-codes. I'm thinking about just buying the ones Stewart mentioned and seeing if they're long enough. But I was hoping someone knew the numbers from experience.
i havent measured myself, but from what i have read on here, a un-modded B code with the 3.5" block is the same thickness as the modded B code with the OEM 2" block.
labman1014 is correct and your setup should be the same as my b-codes modded with the stock 2" block.
I didn't do the rear B codes, it sits level, and I already had the rear Hellwig and RAS installed.
The prices for the OEM was obtained through my local dealer who matched all my online prices, so I didn't have any shipping costs.
Ford OEM Springs
(2) Front V code springs 5200lbs: Part #2C3Z-5310-HA $141.36 / e 282.72
(4) AXLE TO SPRING Front U BOLT - F81Z-5705-ZA $17.10 / e 68.40
(8) AXLE TO SPRING Front U BOLT NUT - N805480-S426 $1.36 / e 10.88
(1) Zone Offroad Ford Adjustable Track Bar 99.95
(2) Bilstein 5100 46mm 2-2.5” Front Shocks Part #33-188297 $80.00 / e 160.00
Front V Code TOTAL 621.95
(4) AXLE TO SPRING Rear U BOLT - N811667-S436 $9.76 / e 39.04
(8) AXLE TO SPRING U BOLT NUT - N620485-S441 $2.17 / e 17.36
(1) 3.5” Left Tapered Block F81Z-5598-FA 0.00 Donated take-offs
(1) 3.5” Right Tapered Block F81Z-5598-GA 0.00 Donated take-offs
(2) Bilstein 5100 46mm 3-5” Rear Shocks Part #33-151656 $80.00 / e 160.00
