Oh no, more v/b code questions that need answers
First of all, Yes I did a search, hence my confusion. I was able to find some part numbers but no definitive answers to my questions.
Ok, here's my problem: I need to replace the front shocks and springs on my 01 Ex (5.4L 4x4). Pass. side front shock is toast and the driver's side spring makes all kinds of racket when it compresses. What I'm looking for is a firmer ride, slightly higher and more level stance. As it stands the truck seems a bit higher in the back and could use a bit of stiffening up. I know that if I'm going to replace what's there, I may as well upgrade to something that will help get rid of some of the wandering and provide a bit of lift. I'm new to the ford truck world and I don't understand alot of what i've read about spring swaps but I'm not new to vehicle modification so I understand the technical info, just not ford specific jargon (i.e.: v,x,w,b codes). Please correct me at any time but, I've determined that alot of owners are going with an f-series v-code front spring / f-250 shock combo, and b-code spring / f-350 block spacer combo (with Ex shocks). Where I'm most confused regards the options for the rear. Do I necessarily have to add a leaf to the b-code rears or can i just do a direct swap and maintain a basically level stance? If my rear springs are ok, do I even have to replace them at all or can i just swap the stock spacer for the f-350 block and do the shocks? That brings me to U-bolts...it seems that there is some confusion on what to use front and rear. Any takers for that one?
Just for background info, truck has 122k miles, ball joints are brand new, steering components are newer (except for stabilizer), I plan to add a rear sway bar prior to spring/shock replacement (no stock bar right now). I plan to replace the rear shocks when the front shocks are replaced. Most likely going with bilstein 5100's all around.
Any help you guys can provide will be greatly appreciated.
Unmodified rear B codes will actually lower your Ex from your stock springs. This is because the Ex spring pack is much thicker and has more leaves. I can't give you any good estimation of how much lower it would be. An inch maybe? Many people modify the B codes by adding a leaf or two from the bottom of the Ex rear springs to the spring pack. I can't remember if it is just the bottom leaf, the bottom two, etc... I'm not sure of all the reasons that people add the 4" factory F350 blocks to the rear, but I believe some people swap in front V codes, rear B codes, then use the 4" F350 block to bring the rear end up and retain the factory rake front to rear.
With V codes added to the front and stock Ex springs in the rear, your Ex will likely sit very close to level, or maybe an inch high or so in the rear (based off my 2.5" higher rear when mine was stock). If you are buying the springs new, you could put them in the front and retain your factory rear springs. This should help with some of the stability problems, as the front factory springs are junk and hit the bumpstops constantly. I have also heard that the problem lies with the rear springs, but at least this way you can see the improvement with just the front springs, and your Ex should sit fairly level. If you want to bring the rear up afterwards, a set of blocks is all you need.
As for U-bolts, they are not intended to be reused after torqued down once. I have reused U-bolts on other vehicles and I know other people who have reused them with no trouble. But I am not encouraging you to reuse them. Regardless of whether you get new U-bolts or reuse your factory U-bolts, always check the torque on them after 100 miles, and every few hundred miles after that for 1,000 miles or so, and then any time the wheels are off or more if you're paranoid like me.
I encourage anyone to correct anything I got wrong here. I was just trying to get the discussion started from what I have gathered (right or wrong) in my reading on this forum.
And one last thing. You really have a four wheel drive Ex with the 5.4L V8? I thought all 4wd Exes had the V10 or 7.3L/6.0L.
People doing the spring mods want to raise the rear-end higher than just what the B codes will provide, because the front springs that are swapped in will raise the front of the Excursion, and "just" B codes can't "keep up" so to speak.
People either use the 3.5" tapered blocks to keep the same front to back stance/rake, or they keep the OEM blocks and modify the B code springs to achieve the approximate same raise in height.
Stewart
Do you tow with it, or intend to tow with it?
Vehicle: Spring Code Spring Capacity
Excursion V8 Cyl B 4100
Excursion V10 Cyl C 4300
Excursion PSD V8 D 4700
F250/350 SuperDuty S 4000
T 4400
U 4800
Camper Package V 5200
Possibly found only on F450 W 5600
Snow Plow package X 6000
As you can see, going from a front spring rating of 4100lbs to a V code with 5200lbs, you're gonna get a bit of a lift. A bit more than the diesel Excursions since your 5.4L weighs a ton less than the PSD's.
Also, don't be confused by the "B" used above for your 8cyl 5.4L Excursion. The above specs are all for front springs. The ones we refer to for the rear...the B codes...are not the ones listed above.
Since you have a 5.4L Excursion, using the V's up front will raise the front end a bit higher than other Excursion owners who have V10's or PSD's because your engine is a bit lighter. So you'll need the lift of new B codes plus, either modifying them ("modded B codes"), using the 3.5" tapered blocks, or you can even install the RAS (Roadmaster Active Suspension) if you plan to tow, because the RAS will also lift the rear.
You also wanna replace the rears because you talk about eliminating wander. The rear springs are very prone to axle wrap so upgrading to new B codes help eliminate that.
You can reuse the front U-bolts, even though for safety reasons, it's not recommended.
I reused the fronts, and replaced my rears with an old set of take-offs I got from a local 4x4 shop, but it's not recommended you do that.
Hope that helps.
Stewart
Let's try this:
Vehicle:
Excursion 5.4L .......... Spring Code .......... B .......... Spring Capacity .......... 4100lb
Excursion 6.8L .......... Spring Code .......... C .......... Spring Capacity .......... 4300lb
Excursion PSD .......... Spring Code .......... D ........... Spring Capacity .......... 4700lb
F250/350 .................... S .......... 4000lb
.................................. T .......... 4400lb
.................................. U .......... 4800lb
Camper Package .......... V .......... 5200lb
only on F450? ............. W ......... 5600lb
Snow Plow package ...... X .......... 6000lb
Stewart
Vehicle:
Stewart
Forgive me for saying B codes provide less height than V codes. Stewart is right, I installed my Vs and Bs without blocks and noticed the rear was way low. I was getting things mixed up. I can only imagine how hard remembering things will be when I get old.
Stewart: So front V codes only came on F250s with the camper package? That has to be a relatively small number of trucks.
Hmmm, I'm wondering if you're getting your springs confused.
V codes are for the front. B codes are for the rear. You can't really compare the two, apples to oranges.
However, your first post compared the height of the B codes to the OEM rear springs on the Excursion, which can be done, apples to apples.
Just for the sake of clarity, rear B code springs will raise the rear of the Excursion when compared to the OEM rear springs.
I resemble that remark.
I wouldn't say "only."
They are found on the camper package trucks, but I wouldn't be surprised if they were also on other trucks without the camper package.
Stewart
Stewart
Thanks for the clarification on everything. To answer some of the q's, I do not tow anything but I do haul things in the rear. I would prefer a level stance but I'm not fanatical about it.
So I suppose my game plan is:
1. Install rear sway bar.
2. Replace front springs w/ v-codes
3. Replace front shock w/ f250 spec units
4. Replace rear springs w/ 'unmodded' b-codes
5. Replace rear shocks w/ Ex spec units
6. Replace spacer with f350 3.5" tapered block
Skinsfan, yes I'm sure that I have a 4wd with the v8 gas motor. Maybe its an uncommon combo? It was some kind of utility spec truck because there is a rubber floor, a plug in the roof where a light was likely mounted and it came with a 'pack rat' steel utility box in the rear area. The box is for sale if anyone wants it.
Your game plan above will get you so close to level (with the rear still being slightly higher) that I think you'll like the look.
Stewart
Thanks Stewart. Has anyone nailed down a part number for rear u-bolts that will work with that setup? From what I read in the searches I conducted, there seems to be a bit of controversy on exactly what to use.
My next step is trying to find out if I have any friends with ford dealler hookups in my area. I'd hate to have to pay unnecessary shipping charges on those heavy springs.
Bigwhitetruck I would think OEM F350 u-bolts would be the correct length since they came with the blocks, and the spring pack thickness, while perhaps different between B codes and whatever a F350 came with, is usually only an inch or so. I imagine Stewart will know for sure though. He is our forum "Exspringspert".
And that is interesting about your truck. It may have been special ordered with the 5.4 either as an emergency response or law enforcement vehicle.
I'll find it for you.
The shipping charges may surprise you.
Stewart
Ok, according to my buddy Ed (PartsGuyEd), if you're using B code spring part number 3C3Z5560CB, then you'll wanna use U-Bolt part number N811667S436 (you'll need 4, two for each side) and the part number for the U-Bolt nuts are N620485S56 (you'll need 8, four for each side, two for each U-Bolt).
N811667S436 U-Bolts are 320mm or 12.598 inches long and should work with the B code springs.
I have not verified this info though, so please make sure it's correct before ordering.
If you want, I can post the part numbers for the slightly longer U-Bolts, and you can always cut them to size with a sawzall if you want.
Stewart
Stewart
