Need help finding V and B code springs
Old Aug 25, 2009 | 08:58 PM
Jbru167's Avatar
Jbru167
I have been trying for weeks to line up some V and B codes springs to do the swap on my 03 6.0PSD but can't seem to find any . Anybody got any suggestions or lifting their truck and want to sell the take offs? May have to order some new ones from the dealer!
Old Aug 25, 2009 | 10:11 PM
BostonX73's Avatar
BostonX73
post a request on the classifieds here - check craigslist, or even post a want add on craigslist.
for my rears I actually found them on CL by my inlaws and had them pick them up. took a few months, but it was winter so not in a big hurry.
if you are in a hurry, probably have to get them from the dealer.
Old Aug 26, 2009 | 07:58 AM
Malikenya's Avatar
Malikenya
Thumbs up Talk to Ed at Y2K parts
I searched locally for a while and all I could find were tired, worn out salvage yard springs. The local dealers were no help; they wanted to charge full retail (~$1300). I scrounged the part numbers off of a couple post here and started looking on-line.
I placed the entire order...all new Ford parts...for about $1000 shipped across the country to my door (WA to VA). Ed worked with me to keep the shipping to a minimum and double checked my order to make sure I got what I needed.
I decided that I wanted to keep this Ex for a while, so new springs made sense (at least that's what I told the wife). I probably could have gotten the cheaper and heavy stuff locally (like the blocks and bump stops) and save some on shipping, but I still saved $150-200.
Here's my order:
<TABLE style="WIDTH: 342pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=456 border=0 x:str><COLGROUP><COL style="WIDTH: 191pt; mso-width-source: userset; mso-width-alt: 9325" width=255><COL style="WIDTH: 49pt; mso-width-source: userset; mso-width-alt: 2377" width=65><COL style="WIDTH: 102pt; mso-width-source: userset; mso-width-alt: 4973" width=136><TBODY><TR style="HEIGHT: 15.75pt" height=21><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 191pt; BORDER-BOTTOM: #ece9d8; HEIGHT: 15.75pt; BACKGROUND-COLOR: transparent" width=255 height=21 x:str="FRONT SPRING V CODE SPRING ">FRONT SPRING V CODE SPRING </TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 49pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=65 x:num>2</TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 102pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=136 x:str="2C3Z-5310-HA ">2C3Z-5310-HA </TD></TR><TR style="HEIGHT: 15.75pt" height=21><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 15.75pt; BACKGROUND-COLOR: transparent" height=21 x:str="AXLE TO SPRING U BOLT ">AXLE TO SPRING U BOLT </TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>4</TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:str="F81Z-5705-ZA ">F81Z-5705-ZA </TD></TR><TR style="HEIGHT: 15.75pt" height=21><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 15.75pt; BACKGROUND-COLOR: transparent" height=21 x:str="AXLE TO SPRING U BOLT NUT ">AXLE TO SPRING U BOLT NUT </TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>8</TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:str="N805480-S426 ">N805480-S426 </TD></TR><TR style="HEIGHT: 15.75pt" height=21><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 15.75pt; BACKGROUND-COLOR: transparent" height=21>SD Ford front Bump stops</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>2</TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">F81Z-3020-DA</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17></TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD class=xl26 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 15.75pt" height=21><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 15.75pt; BACKGROUND-COLOR: transparent" height=21 x:str="REAR SPRING F CODE SPRING "></TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num></TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 15.75pt" height=21><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 15.75pt; BACKGROUND-COLOR: transparent" height=21 x:str="REAR SPRING B CODE SPRING ">REAR SPRING B CODE (w/o aux)</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>2</TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">3C3Z-5560-CB</TD></TR><TR style="HEIGHT: 15.75pt" height=21><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 15.75pt; BACKGROUND-COLOR: transparent" height=21>3.5” BLOCK LEFT (Tapered)</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>1</TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:str="F81Z-5598-FA ">F81Z-5598-FA </TD></TR><TR style="HEIGHT: 15.75pt" height=21><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 15.75pt; BACKGROUND-COLOR: transparent" height=21>3.5” BLOCK RIGHT (Tapered)</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>1</TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:str="F81Z-5598-GA ">F81Z-5598-GA </TD></TR><TR style="HEIGHT: 15.75pt" height=21><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 15.75pt; BACKGROUND-COLOR: transparent" height=21 x:str="AXLE TO SPRING U BOLT ">AXLE TO SPRING U BOLT </TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>4</TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:str="N811667-S436 ">N811667-S436 </TD></TR><TR style="HEIGHT: 16.5pt" height=22><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 16.5pt; BACKGROUND-COLOR: transparent" height=22 x:str="AXLE TO SPRING U BOLT NUT ">AXLE TO SPRING U BOLT NUT </TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>8</TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">N620485-S441</TD></TR></TBODY></TABLE>
If you prefer the F-codes, here is the info (they are more expensive):
<TABLE style="WIDTH: 342pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=456 border=0 x:str><TBODY><TR style="HEIGHT: 15.75pt" height=21><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 15.75pt; BACKGROUND-COLOR: transparent" height=21 x:str="REAR SPRING F CODE SPRING ">REAR SPRING F CODE SPRING </TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num></TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">6C3Z-5560-F</TD></TR></TBODY></TABLE>
It should all arrive soon, then comes a bunch of work (I've got a couple mods ready to install).
Some of the other site sponsors may be closer and save you some shipping, but I would be surprised if they could give you the level of service I got from Ed.
Thanks Ed,
Jud
Old Aug 26, 2009 | 08:44 AM
myblkex's Avatar
myblkex
Hey great info to have Thanks !
Don't forget to verify if your Ubolts are the Flat (Square), Round, or SemiRound type before starting ...
Footy
May 26, 2012 06:58 AM
jeeplj8
Mar 23, 2012 10:52 AM
Tirewarmer
Jan 5, 2011 08:38 AM
Neal 97 250
Apr 27, 2009 10:35 AM
Billholthues
Apr 17, 2006 10:13 PM
