wtf ideas see inside
Old Aug 26, 2012 | 05:28 PM
tims01's Avatar
tims01
ok so here are the details of my WHAT THE **** issue
i have a 2wd 2001 7.3 child hauler .. i have now a new interesting issue .. when going to start the truck the truck sounds like its starting slowly and dying ( keep in mind i usually just jump in and key on then start and go and it is 70*plus here) now i was like WTF so i keyed on waited a second and then it started fine .. this is happening every time unless i wait a few seconds .. then it does not happen ... i watched my gauges and it turns out that the battery gauge is only in the first quarter of range of motion then after a second it jumps to the normal half way mark .. its like there is a switch that takes it from one battery to two battery's ... ( at least that's my feeling on it lol) now im not one for glow plugs because it has not been cold enough for them to need to be used ,.. all it takes to start normally is a two - three second wait .. but it still sounds slow... i checked the batteries and they seemed ok there about two years old .. now one of the cells on one battery was low so i filled it up .. once running everything is working fine.i have no clue what would cause it but oh well
i thought i would throw this out there and see what you all might think it could be
Old Aug 26, 2012 | 05:40 PM
Stewart_H's Avatar
Stewart_H
What are the amps before you turn the key on?
What are the amps while the key is on, glow plugs warming, engine off?
What are the amps when cranking?
Stewart
Old Aug 26, 2012 | 05:50 PM
Stewart_H's Avatar
Stewart_H
Check out these threads:
https://www.ford-trucks.com/forums/1...l#post10806422
https://www.ford-trucks.com/forums/1...l#post11679030
Stewart
Old Aug 26, 2012 | 10:35 PM
tims01's Avatar
tims01
yeah thats what i was thinking .. its been two-three years on these batteries lol especialy with one of them having a bad cell
Old Aug 27, 2012 | 12:20 AM
cameeks's Avatar
cameeks
I was goimg throught that last month to the point I was getting jumped off. Finally there was smoke. Checked the starter the previous owner bought a few months ago from oriellys was actually falling apart.
Old Aug 27, 2012 | 12:22 AM
VQT's Avatar
VQT
You don't wait for the glow plug light turn off before start up the engine?
My 6.0L with checking the glow plug light turn off before starting and it varies in cranking time befor the engine start to run. I am just happy that it started evrytime so far
Old Aug 27, 2012 | 12:29 AM
tims01's Avatar
tims01
no i dont wait for glow plugs .. no need to .. its warm here and when its not she is pluged in .. but its not the waiting for glow plugs its the volt guage .. its only on 1/4 then it bumps to 1/2 .. ill get vid to show you guys its wered
Old Aug 27, 2012 | 12:41 AM
Stewart_H's Avatar
Stewart_H
You do in Vegas? It's warm there!
When the engine is cold, I wait about a two-one thousand count before starting mine, sometimes less. When it's warm I don't wait at all.
Stewart
Old Aug 27, 2012 | 12:46 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
for your 6.0
your glow plugs won't "need" to be on until the motor is in the 50's or colder. they are utilized, and stay on each time you start the X for about 1-2 minutes after running however
I've never seen my glowplugs wait to start light lit
Old Aug 27, 2012 | 01:54 AM
tims01's Avatar
tims01
lol no im in oregun ..lol... it will do this even when its been running for a while and hot
Old Aug 27, 2012 | 02:03 AM
cameeks's Avatar
cameeks
Just grab your starter and try to move it around just to check that. Isnt the volt meter after the starter?
andydunks
Dec 1, 2014 08:54 PM
caseydudem
Dec 27, 2010 06:32 AM
tomherrick
28
Sep 18, 2010 06:06 AM
conman3300
Nov 24, 2008 10:29 PM
MPlayer
Aug 5, 2008 09:36 PM
