Sponsored by: Real Truck
A/C Help needed (Updated)
Old Sep 13, 2012 | 05:06 PM
projectSHO89's Avatar
projectSHO89
Yep, ditto. If the compressor shaft is turning but it ain't compressing, it's done for.
Old Aug 23, 2015 | 09:41 PM
grumpyjo's Avatar
grumpyjo
I have a 1978 F350 Crew Cab, when I got it the AC didn't work at all. First they changed the valve to the evaporator, dryers, and flushed the system and charged it. Ran cold for a couple weeks then seal went out of the compressor. Changed out the compressor, dryer and the condenser coil, ran cool, not cold. Now after two more compressors (seals went out) etc. still runs cool not cold.
Grumpyjo45@hotmail.com
Old Sep 2, 2015 | 03:04 PM
bayou barataria's Avatar
bayou barataria
Has the system been converted to 134a? And are you sure the compressor is charged with the proper amount and type of oil? There are a/c supply places online that will tell you the proper amount on refrig. to put if it is converted, maybe the charge was not correct. r134a requires different seals hoses, and oil than r12 does.
Old Sep 3, 2015 | 06:06 AM
ashleyroachclip's Avatar
ashleyroachclip
I have a 99 , and the bearing in the pulley has gone bad, growling real bad.
Still the w/o works perfectly.
I see that ford no longer sells the pulley.
I have another complete compressor with pulley and clutch, and want to just change out the pulley.
Has anyone done this, and do I need a puller to get the pulley off after removing the clutch?
Old Sep 3, 2015 | 07:25 AM
Vwags's Avatar
Vwags
Nvm 10 char
brettdacosta
May 25, 2017 11:19 PM
cjkittyx3
Oct 21, 2011 10:19 PM
PowerstrokeDude
Sep 21, 2006 10:28 PM
Copper 118
Jun 14, 2004 01:18 AM
lasher
Aerostar
Jun 13, 2004 07:17 PM
