Code question
Old Aug 26, 2012 | 08:55 PM
wicat3's Avatar
wicat3
Ok so I have been looking around and it seems no one can get me the egr canister so I would have to special order it but I found I could make my own. Anyone seen this or done this? It looks like with a short peice of pvc pipe and two end caps I could drill and glue a vacum port and be back up and running like new. Im sure this would be cheaper then ordering a 60-80 dollar coffee can no?
Old Aug 26, 2012 | 09:10 PM
merhlin's Avatar
merhlin
I did it that way on my 95 F150 - I used sch40 pipe and end caps, drilled one of the caps out a little smaller than the check valve (used the one out of my bad canister), and epoxied the check valve on. Quick and easy, and still holding a vacuum after 6 months.
merhlin
Old Aug 27, 2012 | 01:26 AM
Truckin Bob's Avatar
Truckin Bob
merhlin
And that really aligns with the saying, "Necessity is the mother of invention".
Bob
Old Aug 27, 2012 | 06:24 AM
wicat3's Avatar
wicat3
So Merhlin does the check valve just pop out of the canister or did you have to cut it out?
Old Aug 27, 2012 | 09:15 PM
merhlin's Avatar
merhlin
I had to cut it out - actually I used a can opener to remove the top, then tinsnips to get to the check valve, then pliers to pull the sheet metal from the check valve. There is a channel in the check valve that the canister top fits into, and I used the pliers to more or less peel the metal top out of the check valve.
merhlin
Old Aug 28, 2012 | 06:16 AM
wicat3's Avatar
wicat3
Thanks im gathering the parts know lol
scrobbie
Jan 27, 2014 07:10 PM
weberr7
Jul 2, 2012 03:22 AM
mstan99999
1997 - 2003 F150
Jul 28, 2006 01:33 PM
monsters
Apr 1, 2005 11:37 PM
BigDuVall
1983 - 2012 Ranger & B-Series
Mar 17, 2005 08:43 PM
