Need help with FICM install
Old Aug 22, 2012 | 05:13 PM
LionInTheSun's Avatar
LionInTheSun
I'm ready to install my new FICM and while checking out the wiring harness for any damage I notice what appears to be a ground wire that isn't attached to anything. Should this be hooked up to anything. This is in a 05 Excursion 6.0.
Old Aug 22, 2012 | 05:19 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Yup, it goes under that nut right below it ( just inside the circle in your picture). Good catch it does matter!
Old Aug 22, 2012 | 05:20 PM
william_04_x's Avatar
william_04_x
IIRC, that's a FICM ground and should be attached to the nearest intake manifold stud. I believe it's the stud at the very rear.
Old Aug 22, 2012 | 06:30 PM
Fal-308-Win's Avatar
Fal-308-Win
Did you have stc' replaced or valve covers removed? Don't mind my stupid questions, I'm just trying to get my Senior Status
Old Aug 23, 2012 | 09:45 AM
LionInTheSun
Thanks for the help guys.
Old Aug 23, 2012 | 11:31 AM
LionInTheSun
Got the new FICM in started her up and no codes!!!
Old Aug 23, 2012 | 12:18 PM
Rusty Axlerod
Cool
__________
Old Aug 24, 2012 | 05:35 AM
Curt's05's Avatar
Curt's05
Wiser by FTE
When did ford start using the heat shielding in front of the turbo? i dont think i have one!
Old Aug 24, 2012 | 07:49 AM
Rusty Axlerod
It's between the FICM and Y-pipe. Angle of the picture might be messing you up.
Old Aug 24, 2012 | 10:48 AM
daddykitty's Avatar
daddykitty
i don't have that heat shield on my ex either same year...wtf?
Old Aug 24, 2012 | 10:54 AM
metmop's Avatar
metmop
Actually it looks like someone cut a aluminum radiator fan blade off and made a heat shield. All in all it looks like they did a good job. From what Ed at FICM shop has said heat shields are good but you have to make sure air flow is not restricted around the FICM..... hard to tell if that is the case here. Either way I don't think this is OEM from FORD .
Old Aug 24, 2012 | 01:27 PM
LionInTheSun
Spoke too soon I guess. CEL is back on and pulled a P0676. ANy ideas?
Old Aug 24, 2012 | 05:53 PM
Fal-308-Win
That's a ford heat shield go's behind ficm', then behind hpop' cover (connects to it with 2 8mm bolts and then hooks over the egr' cooler. I have one on my 06 truck. Gets in the way when removing the hpop' cover. Hard to get out hard to get in
Old Aug 24, 2012 | 06:02 PM
Fal-308-Win
That's why I asked if someone replaced his stc' fitting. You have to remove the heat shield and that ground wire connects to the same valve cover bolt that holds the heat shield on and there's your guilty party!
Old Aug 24, 2012 | 07:40 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
checked mine today, i have the shield, no tiny ground wire.
uwaidye
Jul 3, 2019 10:38 AM
autox65
Jul 19, 2016 08:59 PM
xrsxtypes
Nov 21, 2015 10:52 PM
black58
15
Apr 5, 2009 08:31 PM
55fordtruck
Sep 8, 2004 08:25 PM
