80/140 in rear diff?
Old Aug 22, 2012 | 05:04 PM
timmyboy76's Avatar
timmyboy76
Guys, can i use this weight oil to flush the rear diff for a day, to wash out whats left of the oil/water mix, i got going on in there, then refill with synthetic?
Old Aug 22, 2012 | 06:19 PM
Shake-N-Bake's Avatar
Shake-N-Bake
I can't see how that will hurt anything...
DISLFVR's Avatar
DISLFVR
Locomotive breath
Just for a day, I don't believe it would hurt.
Old Aug 22, 2012 | 06:26 PM
timmyboy76's Avatar
timmyboy76
good enough for me, thanks guys. Just found as well, wiping the diff cover off, that theres metal shavings/ferrous in there too...not good. SO, gonna fill ur up ALOT, jack rear-end up, turn tires to slosh crap around, then pull cover again. Wipe out the best i can, and fill up with synthetic. Besides this finding, replacing the axle wasnt bad, except for, got in a hurry and installed new seal on hub WITHOUT installing the inner bearing first
Old Aug 22, 2012 | 06:46 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Just an FYI, I did mine the other day, ordered Royal Purple from Advance auto pts and got 15% off. Every little bit helps especially when it's over 20 bucks a quart and it has the friction modifier already in it.
Old Aug 23, 2012 | 07:04 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Put a magnet in there while you are running your "flush" oil, it will catch and keep the metal in one place rather than letting it float around in the oil destroying things. Clean it and put it back with the good oil to hang on to any pieces that might be hanging out in there.
tonefordays
Jan 3, 2012 01:00 PM
Boatbum01
Dec 11, 2010 09:49 AM
Ford79
Mar 17, 2009 05:10 PM
Rus01
Aug 25, 2008 08:59 PM
kellens
Mar 21, 2008 07:43 AM
