Wastegate Problem - Fix?
Old Aug 20, 2012 | 05:32 PM
JumpinJoe's Avatar
JumpinJoe
Pulled the 6500# travel trailer to up to the GA mountains this weekend and on the way back the turbo stopped spooling. Limped her home and pulled these codes also the engine compartment got a little sooty.
I believe the boots are original and with 212K figure all below is needed:
  • 1999.5-2003 7.3L DIESELSITE Engine Boot Kit (After 12/1/98) DSEBK
  • 1999-2003 7.3L DIESELSITE Intercooler Boot Kit DSIBK
  • BigHead® Wastegate Actuator
Is this all I need, and what's the likelyhood that something worse is/has happened (to the turbo, the motor)?
Old Aug 20, 2012 | 05:35 PM
CSIPSD's Avatar
CSIPSD
None of those will fix your issue... More then likely you have a EBPV that is stuck or a boost leak. You do not have a wastegate issue that could cause a no boost condition.
Old Aug 20, 2012 | 05:45 PM
timmyboy76's Avatar
timmyboy76
http://www.riffraffdiesel.com/mm5/me...de=F731-TRB-IB
check the collector behind the turbo. Also, check under the intake tube to see if the ccv tube may have split/fell off. thats alotta soot.
Old Aug 20, 2012 | 08:08 PM
JumpinJoe's Avatar
JumpinJoe
Thanks guys. Good thoughts so far. Like that kit link also.
Old Aug 21, 2012 | 07:42 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Nothing before or after the turbo will make soot. You have an exhaust leak. Either the up-pipes or down pipe is loose/broken/cracked.
Old Aug 22, 2012 | 06:52 PM
JumpinJoe's Avatar
JumpinJoe
Good info. From what I read it makes sense. Besides soot they say leaking increases EGTs (don't have a pyro yet), and from what I found starting to melt (see new pic) perhaps added heat contributed to the turbo ebv code and the melting on the hose that attaches to back of the wastegate accuator.
Old Aug 22, 2012 | 07:07 PM
BigAlsPSD's Avatar
BigAlsPSD
In your first pics it looks like the MAP line rubbed on the cold side intercooler pipe? Is there a hole in it? This will cause a low power situation as the MAP sensor will not see any boost.
Also what turbo EBV code? The only codes you showed were a P1249 and P0603.
Old Aug 23, 2012 | 06:27 PM
BigAlsPSD's Avatar
BigAlsPSD
The red line is your wastegate actuator line, it should be plugged in where it was in your 2nd pic.
Old Aug 23, 2012 | 07:21 PM
bcaughhorn's Avatar
bcaughhorn
id start out with pressuring up the intake to check for boost leaks. 4" pvc cap with a quick disconnet in the air intake tube with around 20 psi. spray soapy water on every connection. if you hear air blowing you may not see bubbles. just have to listen and feel for the air
Wyatte
Sep 26, 2016 08:23 PM
Nixoninc
Jul 17, 2010 10:24 PM
flatlander84
15
May 23, 2009 06:38 PM
FLASH 13
Jul 26, 2007 04:19 PM
