loading a camper
Old Aug 19, 2012 | 08:33 PM
stu78's Avatar
stu78
loading a camper
Hi guys,
I have a 2004 super cab 4.6l with a 6.5 ft bed. I was thinking of loading a 6 foot camper on it. I do have the factory tow package on it but i still don't think it's adequate to pull a camper. I'm guessing the rear springs might be ok but i definitely don't have a sway bar on the rear axle or anything to tie down the camper. First, is there such thing as a "aftermarket camper package" that will bolt on to my truck? Does Ford provide one? I apologize for my ignorance in this subject in advance.
Old Aug 19, 2012 | 08:47 PM
MCDavis's Avatar
MCDavis
What's the dry weight of the camper? Do you know what your payload capacity is? The available payload will be posted on a white and yellow sticker on the drivers door jamb. I have a feeling that your camper will be over your available capacity once you add passengers and gear.
Old Aug 20, 2012 | 10:47 AM
Papa Tiger's Avatar
Papa Tiger
I would stop at the Camper Dealer near you for your needed gear. A few items will add to your drive. Your pro spring shop can help you in the load area so as not to tail drop a few inches. Of course the unload drive may be a little harder. A F250 area is best way to start with wide frame and all but you got the F150 and it will work great with a little help. You definately want to stop sway as much as you can. Making sure of your front is a good start in that direction. Even Bilstein 5100's for more in the package.
postman524
Nov 4, 2010 07:28 PM
BigFord74
Car/truck Buying Advice
Jun 24, 2005 10:38 PM
wadietz
Sep 12, 2004 08:54 PM
MrBeechwood
Apr 12, 2004 01:57 PM
Ronct
Feb 2, 2003 09:25 AM
