slidein camper certification
Old Apr 11, 2004 | 03:16 PM
MrBeechwood's Avatar
MrBeechwood
Hello I was thinking about buying a 1999 F350 Diesel Crew Cab 4x4 Long Bed 6 speed manual.
My question is if it is not slidein camper certified will I be able to modify it to make it slide in camper safe?
Does not seem like it would take to much to do it. When you look at the options for a new trucks under the Camper package option the only thing it lists is Heavy Service Front Springs all for the low price of $160.00
Thanks for any help
Jim
Old Apr 11, 2004 | 11:50 PM
SoCalDesertRider's Avatar
SoCalDesertRider
You can haul a camper on your truck without the certification. The F350's already have the overload rear springs and sway bar so you should be fine there. I don't know why Ford doesn't provide frame-mount tie down anchors and camper wiring in their 'camper package', since those are probably the 2 most important things you need for camper hauling, along with wide mirrors... I wouldn't worry about the front springs, campers put most of thier weight on the rear axle anyways. You didn't say if yours is a dually or a single wheel. If you're hauling a really heavy camper with a single wheel truck, you might want air bags for the rear and heavy duty shocks to reduce leaning. Duallies are usually stable enough as is. My old Chevy dually hauled my 10.5-11' camper great.
Old Apr 12, 2004 | 01:57 PM
Toyman's Avatar
Toyman
The camper package from Ford includes the heavy front springs, overload springs, and an anti-sway bar. You can put a camper on your truck still. Depending on weight you may or may not need the sway bar, but that can be added very easily.
Toyman
Rasalas
Aug 31, 2017 01:45 AM
WYflyfisher
Feb 27, 2017 12:25 AM
afacey
Feb 17, 2017 08:13 PM
Rich K.
New Member Introductions
Apr 7, 2016 10:52 AM
postman524
Nov 4, 2010 07:28 PM
