400 cid backfire
Old Aug 16, 2012 | 08:02 PM
PaytonK.79Ford's Avatar
PaytonK.79Ford
400 cid backfire
Hey guys. I have a 400 in my 79 that I'm rebuilding and I have a backfire issue. When easing into the accelerator, everything is fine. But when you romp into it, when the four barrels open, it pops really loud. I checked to see if my distributor was advancing but I found that the c clip was gone and the arm wasn't attached. I fixed that and it still pops. Wondering if I can get some ideas from y'all!
~Payton K.
Old Aug 16, 2012 | 08:37 PM
OverReved's Avatar
OverReved
Sounds like you are not getting enough fuel discharge from the accelerator pump. Did you rebuild the carb? If you did, then it should be a simple linkage adjustment to get more stroke. If you didn't rebuild the carb, now might be a good time. You used to be able to buy the plunger by itself, but I'm guessing now you have to buy a complete kit. Good luck.
Old Aug 16, 2012 | 08:43 PM
PaytonK.79Ford
I didn't think too much about the carb because it is fairly new. But I had the thought run through my head. I'll have to look and see what I can find out. Thanks!
Old Aug 24, 2012 | 07:12 PM
PaytonK.79Ford
Well, I think I got things figured out. My vacuum pot on my distributor wouldn't hold a vacuum. I change out pots and re-timed everything. When timed 10º advanced, you could wrap it all the way up. But when I shut it off and started it it kind of struggled. I hope now its just a matter of getting things timed right.
Old Aug 24, 2012 | 08:12 PM
400 .040over's Avatar
400 .040over
try setting teh timing @ 6* BTDC
Gradythemachine
Oct 12, 2017 09:58 PM
j74250
Dec 22, 2008 10:01 PM
seabee04
27
May 18, 2004 03:30 PM
AMiller320
Nov 11, 2002 08:36 PM
Ford Trucks Rule
Jan 26, 2002 11:49 AM
