Help With Hardware
Old Aug 24, 2012 | 04:44 PM
outsource77's Avatar
outsource77
Question Help With Hardware
Hello,<O</O
<O</O
My truck is a 76, f100, Flairside, LWB, 2wd, I6 300. I ran a few searches on the net, in the forum and got some good info. I have a few questions.
<O</O
<O</O
First, is there a difference between style side and flairside mounting bolts?<O</O
<O</O
From search info: The bolts from LMC are not the correct hardware, is this still true?<O</O
<O</O
From search info: DC had the correct bolts (bigger and longer square part of the bolt) but I cannot find the bolt on their site, does anyone out there have a part # for the bolt with DC?<O</O
<O</O
Does anyone have or make the mounting blocks for long bed flairside?<O</O
<O</O
<O</O
It look like hardware is as follows that makes up a mounting point.<O</O
<O</O
bolt, Washer, mount point, washer, some type of locking washer and nut
<O</O
<O</O
</O
I would like to get the original type of hardware, if not available.<O</O
<O</O
What type or grade of alternative hardware can be used that is safe (bed won’t go flying off) and still keep the carriage bolt look?<O</O</O
<O</O
Answers to any of the above questions is greatly appreciated and thanks.
Old Aug 24, 2012 | 05:26 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Yes, there is a difference between styleside and flareside bed mounting bolts.
The Ford P/N for the styleside bolt is 384865-S40. This is a 1/2"-13 X 3 3/4" Bolt.
The flareside P/N is 384913-S40. The only info the parts catalog gives is it's a 1/2"-13 phillips head screw but doesn't give any length or details.
Old Aug 24, 2012 | 07:34 PM
keiths78f150's Avatar
keiths78f150
Mike ALWAYS brings the knowledge to these forums.
Old Aug 24, 2012 | 07:47 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Thanks Keith, now for the bad news. I did a search for the 384913-S40 bolt, the ONLY ones I could locate are in Russia !!!
I never really paid any attention to them and don't have any handy to look at, but I have a feeling that they are flathead phillips screws 1/2-13 NC thread unknown length.
I'll look a little further and see what I find out.
Old Aug 24, 2012 | 07:52 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Okay, Dennis Carpenter has the flareside bed bolts too. They're P/N 350623-S and are $3.50 each. He also has the countersunk washers and lock nuts.
Old Aug 24, 2012 | 10:34 PM
outsource77
Right on MikeO, thanks! Cool, knowledgeable people that's why I keep coming back to this site.
Old Aug 24, 2012 | 10:46 PM
Tans73F250's Avatar
Tans73F250
You can also use grade 8 alternative bolts. its just a matter of finding the right lengh and size but they are strong enough
Old Aug 24, 2012 | 10:49 PM
hasteranger's Avatar
hasteranger
you should put some pics up of your truck, not too many flaresides around with stock beds.
MPD56
6.7L Power Stroke Diesel
1192
Oct 31, 2024 04:40 PM
Lex2002
47
Sep 23, 2013 09:53 AM
DIYMechanic
15
Jun 20, 2011 08:29 AM
chuck362
Nov 5, 2009 11:28 AM
muleburrow
Feb 3, 2006 09:44 PM
