holley 2 bbl hesitation
Old Dec 22, 2008 | 08:58 PM
j74250's Avatar
j74250
i have a '79 supercab 4x4 with a stock 400, performer intake and i just put a rebuilt holley 4412 2 bbl 500cfm carb on it. it runs and idles flawlessly but upon ecceleration it hesitates, almost dieing. cant figure it out, any ideas???
Old Dec 22, 2008 | 09:10 PM
fmc400's Avatar
fmc400
MSEE
Sounds like an accelerator pump issue. With the engine off, pull the air cleaner off and look down the throat of the carb. See if you can see any fuel shooting across the venturis when you pull the throttle black.
Old Dec 22, 2008 | 09:14 PM
j74250's Avatar
j74250
did that and fule is going out the nozzles
Old Dec 22, 2008 | 09:17 PM
fmc400's Avatar
fmc400
MSEE
Next check your timing, and that your vacuum advance is functioning properly. Pull the distributor cap off and apply vacuum to the advance and make sure the breaker plate moves back and forth. How'd it run before the reman carb?
Old Dec 22, 2008 | 09:19 PM
j74250's Avatar
j74250
had an edelbrock 4 bbl on it and i didnt have any probs. i wanted to get a little better gas milage with it and it did come with a 2bbl so i got a nice deal on it and a kit
Old Dec 22, 2008 | 10:01 PM
fmc400's Avatar
fmc400
MSEE
To tell you the truth, you'll probably get better mileage just leaving the 4 barrel on there. The Edelbrock will have smaller primaries which is what you'll be driving on most of the time. Only when you punch the gas does the rest of the 4 barrel open up.
