chuggin 360
Old Jan 25, 2002 | 09:17 PM
Ford Trucks Rule's Avatar
Ford Trucks Rule
chuggin 360
i got a 68 360 f100. I put a new distributor in it about a month ago. and i just changed the point 2 days ago. (its a single point) But recently when i drive around for about 30 minutes or so the engine chugs really hard when i accelerate. what could this be? i was thinking about doing a carb rebuild (when i take the air cleener off i can see gas under the carb sometimes (on the block). Oh yea its not the fuel filter its new and all tightened tight. Do any of you all know what the problem might be? Is it hard to rebuild a carb. its a 2bbl holley. Oh yea, i know the problem isnt the choke stuck open.
Please help. Thanks
Old Jan 25, 2002 | 10:26 PM
lastchance's Avatar
lastchance
chuggin 360
[updated:LAST EDITED ON 25-Jan-02 AT 11:31 PM (EST)]If you're sure your points are gapped correctly you may want to check your timing. Every degree of dwell you are off throws your timing off a degree. Another thing I'd check is the little ground wire that grounds the breaker point plate in the distributor. When your vacuum advance kicks in, the plate moves, and if that wire is off or broken your ignition will "break up". You could also just pull the hose off the vacuum advance on the distributor to check it, and see if it makes any difference.
Edit: Forgot about the carb. Sounds like your accelerator pump is leaking, which is plenty enough to make it buck while accelerating! It's right there on the front on the driver's side, held on with four bolts. If the truck is running good and the carb looks clean you can replace the pump without even removing the carb from the truck. Those carbs are fairly easy to rebuild, but if it's just the pump you can get away with just that. Used to be able to buy the pump seperate from a whole carb kit, but the last time I went to get one I had to buy the whole kit.
Old Jan 25, 2002 | 10:47 PM
Ford Trucks Rule
chuggin 360
Do u have to set a gap on a Point? I have a single point distributor.
Old Jan 25, 2002 | 10:57 PM
Mil1ion's Avatar
Mil1ion
chuggin 360
[updated:LAST EDITED ON 26-Jan-02 AT 00:00 AM (EST)]Yes,
.018"
Forgot ,Make sure the points cam is greased.
Fast way to wear out points is to leave it un-greased.
Dennis
Oh....Please Don't Ask Me Any Tough Questions As:
"I'm Saving Up MY Memory For When I Develop Alzheimer's"
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=144&.jpg
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=143&.jpg
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
Old Jan 26, 2002 | 07:28 AM
jowilker's Avatar
jowilker
chuggin 360
Old Jan 26, 2002 | 07:37 AM
Ford Trucks Rule
chuggin 360
ok, u all gotta help me. What should i look for when setting the gap on a point
Old Jan 26, 2002 | 09:01 AM
lastchance's Avatar
lastchance
chuggin 360
Take the distributor cap and rotor off. Look and see where the point set contacts the cam in the distributor. Bump the engine over until the points are open as far as they will go, when the little plastic block on the cam is sitting on one of the high points on the distributor cam. Take the feeler gauge and measure the opening (I think it is .018 as posted above). You'll see the point set has a slotted hole in them. Loosen the screws slightly and move the points until you get the feeler gauge to just pass through the contacts. Then tighten them down and recheck them.
You may also check that accelerator pump as well. Take the air cleaner off and open the throttle on the carb a couple times, it doesn't have to be running. If you are getting gas leaking from the accelerator pump it's gonna make it run bad as you first accelerate too.
Old Jan 26, 2002 | 09:26 AM
Ford Trucks Rule
chuggin 360
ok, i took the cap and rotor off then i i tried to start it and the point didnt open at all
Old Jan 26, 2002 | 11:49 AM
Mil1ion's Avatar
Mil1ion
chuggin 360
Why aren't the points opening?
Well,
1)The mounting /adjustment screws could be loose.
This is my guess
2)The Compound part of the points that rubs against the cam is worn down from lack of lubrication
3)The distributor shaft isn't turning.
Without scanning 4 pages of instructions I have to send you to this site.
I hope you have Adobe acrobat for reading.
Please read this :
http://www.championauto.com/championauto/pdf/4.pdf
Dennis
Links_vette
Mar 31, 2009 04:44 PM
arbuckles3
Dec 25, 2008 02:22 PM
stealth1
May 7, 2008 12:56 AM
Hellbore
35
Jun 11, 2006 01:40 AM
CRJ900
Feb 8, 2002 01:34 PM
