Carb problems
Old Oct 12, 2017 | 09:58 AM
Gradythemachine's Avatar
Gradythemachine
Carb problems
just rebuilt 1406 edelbrock on a 400 i just rebuilt earlier this year. It starts up and revs fine in park but in drive it wants to die when you even think about moving the pedal more than an inch. Any idea??
Old Oct 12, 2017 | 12:28 PM
Dave145's Avatar
Dave145
Sounds like the accelerator pump is shot or not installed correctly.
Did it do this before the rebuild?
Old Oct 12, 2017 | 03:08 PM
HoustonDave's Avatar
HoustonDave
Any issues like a higher idle than you used to have? A big vacuum leak can also make an engine die under load.
Old Oct 12, 2017 | 09:41 PM
Gradythemachine
Dave145- I rebuilt the carb when i bought it, first time ever doing one so it is possible i installed it wrong.
HoustonDave- Cant really compare how it use to be to now. I did a full rebuild and it has a different cam, intake, and a four barrel. It idles fine wherever i set it to. I dont think I have any vacuum leaks that im aware of, but i will spray some ether around tomorrow.
Old Oct 12, 2017 | 09:58 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
LOOK DOWN THE THROAT OF THE CARB, OPEN THE LINKAGE, GAS SHOULD SHOOT OUT!!! If not there is a problem, follow up for additional help and if you would like it to run right, reinstall that edelbrock in the trash and put a holley on. A holley 500 probably would run harder than the edelbrock 600.
MikePacey
21
May 6, 2011 12:37 PM
Fordby4
Bronco II
Nov 8, 2010 06:55 PM
vesuvius5402
Jan 2, 2006 01:53 PM
seabee04
27
May 18, 2004 03:30 PM
OldFords
Nov 25, 2002 07:32 PM
