pulsing amp guage!!
Old 08-15-2012, 11:00 AM
sweetiepie1's Avatar
sweetiepie1
sweetiepie1 is offline
pulsing amp guage!!
My '66 F350 dually has an amp guage that pulses with about the same tempo as a turn signal. When I turn on the headlights, they dim when the guage pulses. I have recently replaced the alternator & the voltage regulator. Any Ideas??
Old 08-15-2012, 06:02 PM
66crawler's Avatar
66crawler
66crawler is offline
My 64 does that also but only at idle, I think its the voltage regulator working.
Old 08-15-2012, 06:36 PM
fordpt's Avatar
fordpt
fordpt is offline
When you push the accelerator pedal does it steady and charge?
Old 08-16-2012, 07:13 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Flickering (pulsing) amp gauges with generator or alternator is common on these trucks when idling.
Old 08-16-2012, 09:15 AM
sweetiepie1
pulsing amp guage
It does it if the engine is running at any speed. The weird thing is that the headlights also pulse by dimming at each pulse. The oncoming traffic seems to think I am trying to warn them of a radar trap, as I get the "high sign" from them. I could go along with the "common occurence on '66 trucks" but not the headlight problem!!
Old 08-16-2012, 01:51 PM
1972RedNeck's Avatar
1972RedNeck
1972RedNeck is offline
Bad regulator. I had one do the same thing on a '76.
Old 08-16-2012, 03:06 PM
sweetiepie1
ANOTHER #@$%#@ regulator!!
I replaced it once, but I will check it out...Thanks!!
Old 08-16-2012, 06:04 PM
fordpt's Avatar
fordpt
fordpt is offline
Get your battery tested, or charge it overnight and check the gauge again with your lights and heater on.
Old 08-17-2012, 12:52 AM
garbz2's Avatar
garbz2
garbz2 is offline
The Amp Gauge uses a separate harness. This harness starts out on the inner apron at a phenolic block and runs 100 percent of the power through the loop on the back of the gauge then back out to the truck harness (basically it interrupts the stock harness and makes a long trip).
Check the mount and the cables for corrosion. No amounts of parts throwing at it will fix the bad wiring.
Garbz
Old 08-17-2012, 09:28 AM
sweetiepie1
pulsing amp guage(and headlights)
Thanks, guys... The battery check out OK, but I will check the wiring & ground. There are not many more parts to throw at it....
88PONY
07-03-2010 04:07 AM
1983 3004x4
Electrical Systems/Wiring
13
12-25-2007 02:23 PM
Avanti
08-24-2004 02:13 PM
Wakeboarder141
1978 - 1996 Big Bronco
04-23-2003 02:40 AM
judge79_1
11-12-2002 08:50 AM
Quick Reply: pulsing amp guage!!
