speedometer guage not working
Old Aug 13, 2012 | 04:04 PM
Andy's7.3L's Avatar
Andy's7.3L
I have a 99 f-250 7.3L super duty.
My speedometer guage in the cluster is not working properly. It may be affecting my turbo etc.
the meter doesnt read over 40mph and when I get to speeds of 75 or above it drops down to 0 and doesnt read at all.
Any ideas to what that could be?
p.s. I've already replaced the sensor on rear differential.
Old Aug 13, 2012 | 04:14 PM
snakedoc's Avatar
snakedoc
welcome to FTE.
i see you have do the thing i was thinking of the ABS on the rear.
did it just start are has it been doing it a long time?
Old Aug 13, 2012 | 04:16 PM
Andy's7.3L's Avatar
Andy's7.3L
thanks for the welcoming. I'm pretty excited to work together here.
I bought the truck around christmas and its been doing it the whole time. I didnt notice it before..I wont miss something like that again ;-)
Old Aug 13, 2012 | 04:21 PM
429 f-100's Avatar
429 f-100
deleated post read thru . sorry
Old Aug 13, 2012 | 04:22 PM
snakedoc's Avatar
snakedoc
if it was doing it when you bought it i might pull the cluster out and make sure it is plugged in good.
other then that i will have to let someone comment on it.
Old Aug 13, 2012 | 04:29 PM
Andy's7.3L's Avatar
Andy's7.3L
I really appreciate all replies. Trying to get this solved along with a few other things.
Old Aug 13, 2012 | 06:24 PM
Andy's7.3L's Avatar
Andy's7.3L
Just picked it up from tech who was doing some work for me. Apparently the engine isn't getting warm enough. Any thoughts?
Old Aug 13, 2012 | 07:51 PM
SuperDoodie's Avatar
SuperDoodie
Sounds like a bad sensor
Old Aug 13, 2012 | 07:53 PM
snakedoc's Avatar
snakedoc
if it is true then the thermostat may be bad.
Old Aug 13, 2012 | 11:03 PM
1fixitman's Avatar
1fixitman
If the thermostat is bad or the gasket is flipped...there are many on here that say to replace the thermostat with a ford OEM part as some of the non oem's fail quickly. Just what I have read about thermostats so far on this board.
D Rock
Old Aug 13, 2012 | 11:13 PM
BigAlsPSD's Avatar
BigAlsPSD
How does the PCM not seeing a correct temperature or the engine not getting hot enough cause your speedometer to not register above 40mph?
Ask your mechanic that...
Are you also getting an ABS light?
Where did you get the ABS sensor (VSS) for the rear end and what P/N?
Have you inspected the wiring for the VSS?
Have you checked your oil in the rear end to make sure there aren't a ton of metal shavings causing buildup on the new sensor?
Have you inspected the tone ring that the VSS picks up on?
Old Dec 11, 2013 | 01:11 PM
WalkingTall's Avatar
WalkingTall
Did you find a solution to your Speedometer problem? I'm having a similar issue with my 2002 F250 diesel. The speedometer might register zero or 105, but usually when I take off, it will immediately jump to 75 and stay there no matter what speed I'm driving.
The ABS light was on, but had that issue addressed. No ABS light now, but Speedo still not working.
All other gauges and lights work just fine. Fuses seem to be all fine. Could it be that the instrument cluster is bad? How would you check this?
Old Dec 11, 2013 | 03:12 PM
SpringerPop's Avatar
SpringerPop
Do you have cruise control, and if so, can you engage it?
Pop
gooberff
Jun 6, 2019 07:04 PM
Andy Drumm
1997 - 2003 F150
Apr 18, 2011 05:44 PM
remmers
21
Nov 9, 2009 07:42 AM
Sweetred95ta
Sep 20, 2006 12:20 PM
sxr785
1997 - 2003 F150
Mar 28, 2004 01:28 AM
