Speedometer??
Old Apr 17, 2006 | 09:38 AM
Sweetred95ta's Avatar
Sweetred95ta
Speedometer??
How do I know if it is my sensor in the rear or the actual guage? I pulled my posi-unit out and checked out the ring, and it seemed fine. I pulled out the sensor and cleaned it and it looked fine. How much is supposed to stick into the rear end? Mine just has like a 1/16 of an inch, maybe. It seemed right. I need to know how to check the cluster or figure out where I need to spend the money to fix the speedometer. I've searched too and couldn't really find anthing. Any help would be appreciated.
Benji
Old Apr 17, 2006 | 01:02 PM
andym's Avatar
andym
The sensor in the rear end is so simple it almost can't fail. It has no moving parts, it's just a magnet that sends a signal back to the computer when metal (the teeth on the gear) passes under it.
If your ABS light hasn't come on, then I would definitely assume it's the speedo head itself. The only other part in the system is the wiring to the sensor. But if the ABS is fine, it has to be the head.
Old Apr 21, 2006 | 07:29 PM
blindlightguy's Avatar
blindlightguy
Asuming your working on your '93 this may be a little diffrent, but on my '87 the conection to the speedometer is an actuall physical spinning linkage. In order to check your speedometer the shop manual sugests pulling the dash out first. Then driving the truck to see if the speedo cable is moving. If it is then it's your instrument cluster.
You can also disconect the cable from your transfer case and spin it by hand to see if the instrument cluster moves.
The sensor in the rear diffrential is for the RABS. And in the 87 at least has no bearing on the spedometer.
I may be way off and your truck may be diffrent. But I would start there.
Blindlightguy
Old Apr 21, 2006 | 09:00 PM
andym's Avatar
andym
His truck is way different from yours. 91 and older F-series use a mechanical driven speedo like yours. 92 and newer use the VSS to control the electronic speedometer.
Old Apr 21, 2006 | 09:31 PM
blindlightguy
Ahh,
I thought it had probably changed it some where in there.
Well sorry I couldn't help.
Blindlightguy
Old Apr 21, 2006 | 10:09 PM
FghtinIrshNvrDie's Avatar
FghtinIrshNvrDie
Yeah, the way those speed sensors fail is usually moisture or whatever ruining the thing. It's not mechanical at all, as andym said. I had mine go out, couldn't figure out why. The guy at the dealership told me to put some silicon up there and seal something or other off... can't remember exactly. Unless you're transmisison is bucking severely, I doubt this is the problem
Ryan
Old Sep 20, 2006 | 12:20 PM
Sweetred95ta
Post revisited: I had to park the truck for a while and now I'm trouble shooting now. By speedometer head, do you mean the gauge in the cluster?? If so, I guess a junkyard would be the best place to look?
Noval334
Jun 26, 2019 04:39 AM
itsnotblue
Jul 1, 2010 11:11 AM
kona56
Apr 5, 2010 02:13 PM
arnegrant
Aug 5, 2009 12:20 PM
boothtec
Apr 23, 2006 11:27 AM
