Sponsored by: Auxito
speedo trouble!
Old Mar 26, 2004 | 11:15 PM
sxr785's Avatar
sxr785
Angry speedo trouble!
i have a 97 f-150 and when ever the outside temp gets above 55 degrees the the speedo quits working below 55 deg it works fine. can anyone tell me why this happens and how to fix it? i have been to the local ford dealer and they have no idea how to fix it. any ideas would be great!
Old Mar 27, 2004 | 08:11 PM
Racerguy's Avatar
Racerguy
Hi sxr785 and welcome aboard
I've never seen that happen before. If you do a search in the forum here you'll find some posts about speedo problems. You could have a bad connection in the circuit board on the back of the instrument cluster.
If I was working on the truck at the dealership I would monitor the Vehicle Speed Sensor signal while out on the road to see if the VSS is actually sending a signal to the cluster or not.
Maybe HomerWinzlow or Troll will come along and have some more ideas. They may have seen this before.
Old Mar 27, 2004 | 11:02 PM
superrangerman2002's Avatar
superrangerman2002
Could it be his rear abs sensor causing this in some remote way?
Old Mar 28, 2004 | 12:37 AM
Racerguy's Avatar
Racerguy
Yup, that's why I'd want to monitor it and see if it's working.
Old Mar 28, 2004 | 01:28 AM
sxr785's Avatar
sxr785
thanks guys for the info!
